MPG MASTERS 1
Block 4 keeps reading 0.0 no matter which way I turn Cam
Hi Guys,
Trying to lower fuel consumption by going more - negative with the torsion value.
I started at -1.4 and turned the cam CC and expected a greater - negative number. It read 0.0 and idled really rough for a few minutes and stalled twice.
I moved the can forward a small amount and the Block 4 still reads 0.0 but the engine runs great and Block 15 went from .401 to .201 at idle and at 2000 rpm went from 1.401 to 1.201 so it is indicating less burn rate.
But, I don't understand why I am reading on Block 4 0.0 even with moving the cam forward from a know - position.
Could I be out of the sensing range?? in a large - negative range. I think I moved it well past the zero positing.
Is there a null position? If so, when I moved it some, it should of indicated a more negative or positive number, yes?
My Indicated MPG seemed to also get a Hugh increase so I would really like to know where it is at.
Block 13 is reading -.09 .02 .00 .05 at idle so they are pretty close.
Hi Guys,
