techdiver74
My Jetta wagon (golf wagon here in Canada) has worn out the rear tires already with only 25,000 km on it. The outside half of both tires is worn down past the wear bars.
I brought the car in for the first service and it says rotate tires. I now found out that the dealer ship I am servicing at did not rotate the tires or inspect them at all. It went in for second service early because of the noise and my finding.
They found the Camber was out out by 1 degree on the back end on both tires and now want to charge me $175 for the alignment and $480 to replace the tires.
1. is this not an issue from the factory? In setup of the vehicle.
2. if they rotated the tires like it said in the first service they signed off on, should they have caught this then?
3. VW customer service line was called and they were of no help. Only told me they could log a complaint for the dealership and nothing else.
I did call where I bought the car (different location as I now live in a different place) they are going to call VW Engineering and talk to them but in the end they feel the dealer I am working with didn't do the proper job and I will have to deal with them in the end.
