IXLR8
- From what I understood, there is an issue with the coding in the air bag controller. The earlier versions of VagCom while working correctly, would trigger a code and the air bag controller would have to be replaced to clear. The later versions of VagCom have been changed to fix this issue, not sure what rev the change happened.
- My ABS light is on... VagCom says it is my right rear ABS sensor is bad, SGII says there are no codes!!??
