Diesel lifer
So, I own a 2006 Jetta TDI MK5 (BRM) and its making the wonderful hissing noise that seems so common to this model year. It only has 85k miles on the engine, and everything else seems to work fine.
I took it to the dealer, (gasp) and after 125 bucks they told me that the EGR cooler needed to be replaced. I said, okay, I'll do some research. They were asking just shy of 1000 to replace it.
After research I found, yes, its the cooler, yes it can be replaced by the lowly (non-dealer) mechanic I am. However, the part is prone, if not certain, to fail again, I have learned. So, might as well block the darn thing off and chip the ECU.
My questions are these:
1) What are the drivability issues that this failure leads to, other than a loss in around town milage that is apparent?
2) How difficult is this really to undertake one one's own? ("one" being a competent mechanic, and for both changing the EGR and blocking it off)
3) What device actually measures the exhaust flow through the EGR, and how does it do it? (I have heard that just putting on block off plates turns on the CE light and returns piss-poor performance from the car, without chipping)
The above is most pertinent, because chipping is cool, but for now, a quick fix, would putting in block off plates on either end of the EGR and leaving it on the car, letting the cooler valve flap away to its heart's content seems like an okay deal unless there is another device that responds to the ECU that I cannot bypass without a chipping.
any help I can get from the amassed knowledge of this forum is greatly appreciated!
