Hi all,
This is my first post here but I've been trying everything I can think of to sort this out.
I have a 2005 SEAT Cordoba 1.4 TDi Sport (82 bhp) It is fitted with a traction control system to try and keep all those 82 horses under control.
Anyway what has been happeniing is I'll be driving along minding my own business when the traction control warning light comes on and stays on. I tried pressing the TCS switch on and off but it makes no difference it stays on until I switch the engine off. (bizarrely enough my cigerette lighter stopped work dispite the fuse for it being fine and I've noticed a tendacy to go through side lights as well)
I took it to a main SEAT dealer as my normal mechanic said they didn't have the necessary tools etc to fix the issue, but they were useless, they carried out a normal service on the car, replaced the front bushes which they said were done, told me I'd needed new tyres which they wanted to charge a fortune for and said they're was no issue with the traction control. I though to myself that maybe the front bushes being worn had caused the traction control to play up so I left it at that but didn't even get out of their forecourt before the warning came on. they then took my car for another day trying to analyse the fault I brought it in with in the first place
After a day with them they said they briefly got a reading about alternator load but were getting a steady current from the alternator so they cleaned all the earthing points on the car but that made no difference. By this stage I was loooking at a €500 bill. I was then told they could replace the alternator for another €500 which may or may not fix the issue or they may have to re[place the cars diagnostic computer which was going to be a major bill..
I decided to take it home and buy a full set of new tyres fitted and balenced from my local tyre fitters at a considerable saving from what they were quoting.
I bought a VAG fault diagnosis kit on ebay for €20 and scanned the car myself I got these two faults (one more than the trained professionals):
Address 01: Engine
Controller: 045 906 019 BG
Component: 1,4l R3 EDC 0000SG 5180
Coding: 00105
Shop #: WSC 06402
VSSZZZ6LZ5R187756 SEZ7Z0E2935233
1 Fault Found:
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Controller: 6Q0 907 379 AB
Component: MABS 8.0 front H03 0001
Coding: 0000008
Shop #: WSC 06403
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 000 - -
I then got my local independant auto electrician to recondition my alternator he fitted new bearings, a new regulator and even changed the pully belt (apparently it should slacken under deceleration and mine was locked up) that was Friday evening, I took it home and everythng was great until Saturday morning where I had to drive down to another town and the warning light came on again.
I took it home rescanned it with my diagnostic kit and got the same errors. I took a voltage reading from the battery and it was a steady 14 volts.
I spent yesterday afternoon with the car sitting and the engine running which I had the diagnostic kit and volt meter hooked up. I got a steady 14 volts all afternoon but the faults were where it got interesting...
The diagnostic kit would clear the ABS fault and the traction control warning light go out but when I went to clear the other Engine alternator load fault, it would immediately reappear and also trigger the ABS fault and the warning light would come on.
If I switched the engine off then restarted and rescanned, the faults would be gone for a while then reappear with the same results. If I kept trying to clear the results eventualy I'd clear the engine alternator load fault then the ABS fault and it would stay fine for a about ten minutes or so then they'd both come back and the same thing would happen again.
I'm fairly sure the ABS / traction control issue is a reaction to the first fault but I don't know what is causing the first fault - the alternator has been rebuilt..
I have my NCT (National Car Test) due this month and I think they'll fail it on this. I can't afford a new car and I can't afford to keep throwing money at a six year old car with 170K+ KM on the clock so I'm left with these options:
Address 01: Engine
Coding: 00105
Shop #: WSC 06402
1 Fault Found:
Readiness: N/A
Coding: 0000008
Shop #: WSC 06403
1 Fault Found:
P1857 - 000 - -
- Put it through the test and hope it doesn't show up
- Disconnect the warning light in the dashboard and put it through the test
- Park the car in the seediest part of town with a can of petrol and a packet of matches next to it - i'm joking about that one
