I'm going to change out my flywheel and clutch due to it making noise. I have heard that it will cause vibrations. I'm thinking about an XTD clutch or Gripforce. Anybody have any experience with these two??
Never heard of those clutches. I recommend the Sachs G60/VR6 with a regular non-lightened flywheel. Very solid setup. You will get a bit of transmission rattle at idle, but it's not that noticeable with a non-lightened flywheel. Mjmautohaus had the kit for $350.I'm going to change out my flywheel and clutch due to it making noise. I have heard that it will cause vibrations. I'm thinking about an XTD clutch or Gripforce. Anybody have any experience with these two??
No. If you do have a lightened flywheel you will notice it a lot. The reason for the dual mass was that it absorbed the engine shock from each piston firing. It vibrates a little more at idle and since it is a SMF there isn't anything extra moving on the flywheel to absorb the piston firing. But that means there is less things to come apart.I would guess that the vibration people are talking about is from the lightened flywheel.
not on earlier TDIs although there are alignment marks on belt cover and harmonic balancerWhy do you need a TDC mark when during TB replacement crank is being locked at the pulley side?
thats lighter than A3 gasser flywheel ...good infoThis one is 22 lbs. http://metalmanparts.com/product.sc?productId=322&categoryId=49
You should know that the flywheel I got from him did not have a TDC mark so I had to transcribe it.
Clutch chatter is noticeable but just about as loud as the diesel clatter.
