I have a 2000 Jetta with 288000 miles. I have been having a problem when the engine would run fine at full power but then once in a while I would loose power. I would shut the engine off and restart and I would be back to full power. Lately I have had the check engine light come on and then would loose power again(more frequent). I have reset the code with a Actron scanner which indicated that it is the turbo/waste gate. Has anyone else experianced the same problem and does it look like that the Turbo needs to be replaced? Or should I look at something else like the MAF? Thanks for any help.
