PolitesTDi
I have a computer but I'm not sure where to go from here. I've run the auto scan and am only seeing window faults (which I am acutely aware of).
NO glow plug faults. I'm not sure if this rules out a glow plug issue or not. After doing a bit of research, it seems like maybe it is a fuel issue. I added a bit of Diesel Kleen with this tank and now it has a hesitant start.
Will my Vag-Com tell me if it's a fuel/filter/injector issue. What scan should I run?
I know that fuel injector cleaning is very expensive. I will probably sell the car before I spend $1000 to clean the injectors.
I'm just running an Engine Scan under the Common tab. In the "injector" part of the scan that gives 10 separate fields, I came up with (000) in three of the fields and numbers ranging from 255 (in field 10) to 038 (in field 2). I'm not sure if this is a normal reading or not. I'm being give a bunch of information that means very little to me. Is there a base line out there or a website that will analyze the readings for me?
I'm considering getting a bluetooth OBD adapter for my Android and just downloading an app like Torque or Car Doctor. Any suggestions, on that front?
Thanks for your feedback!
