O.K. back from dealer with a smile. P13ce P13do, bad cylinder #1 glow plug. C.P.O. covered @ 0 cost.
A little info. gathered that may help others with these cars.
1) Modifying with a tune. According to the tech. the 2011 ecm can not tell if you had a tune and went back to stock for warrenty work. According to him the 2011 isn't new enough to have a counter like the newer years. IF this is true/confirmed a non delete tune is, well... Any confirmation input?
2) Confirmed with service writer that the Polar F.I.S. isn't a warranty killer, as it has no bearing on the drivability etc. yahoo.
3) I asked while the tech was in the diag. if he could report the ash load. My DPF has ONLY 5k miles on it. I have been particularly interested in watching the numbers (soon w/polar FIS). Looking at them I need some help from experienced read of the ash load #'s & metric to miles conversion help. Here it is exactly as written on paperwork:
"Preformed test plan for ash load measurement and found the test load is currently
78 . 0ML and is still far below the maximum load of 200ML Test plan states after apx. 122000KM of driving will be necessary to replace the particulate filter."
Side note 200ML is lower than the 250ML max I've read about before???
