Old August 21st, 2016, 17:51   #46
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
take the shaft and cover assy out of the transmission. Rotate the cover left and right, there will be a detent in each direction, and one in the middle. If the transmission is in neutral, then the one in the middle is the one you want.
Also, you can install the shift lever (golf club) onto the shaft, to hold it in place, and rotate the cover with the shaft held. That way you don't have to worry about the shaft moving the transmission out of neutral (which really isn't an issue anyway, as you can easily put it back into neutral later)
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old August 21st, 2016, 18:06   #47
schoolofdouglas
TDI(s): 2005
Thanks Windex. I'll give it another try in the morning.
schoolofdouglas is offline   Reply With Quote
Old August 22nd, 2016, 10:45   #48
schoolofdouglas
TDI(s): 2005
when i try to install it in the center, neutral, position, the holes don't line up. i just tried lining up the shaft key to the front and the holes to match. it definitely wasn't the correct position, but it did seat properly. i had reverse, although a bit clunky, and the middle position gate. it didn't pull up. I knew it was wrong, but that's the only way i can see it going in properly. going to take it back out now and regroup...again.
thanks for any help.
Old August 22nd, 2016, 12:31   #49
schoolofdouglas
TDI(s): 2005
finally got it installed. thanks for the help.
Old April 21st, 2019, 17:22   #50
BakoTDI
BakoTDI's Avatar
Originally Posted by Ausgezeichnet TDi View Post
CADGUY, thanks for the reminder! I'll put them on the club server.
I donít see any pics still
I gotta see these pics in order to make sure Iím doing this properly
Thanks for the write-up though
99 Canyon Red MK4 Jetta, 5-spd, South Bend clutch Stage 2 Endurance, Firad P502 nozzles, Stage 3 Malone Tune (testing phase still)..I'll eventually get to a bigger turbo
BakoTDI is offline   Reply With Quote
Old April 21st, 2019, 17:25   #51
Yourbuddysatin
Fuel Economy: 32-35mpg
There really isn’t much to changing it....
Yourbuddysatin is offline   Reply With Quote
Old May 17th, 2019, 08:22   #52
BakoTDI
BakoTDI's Avatar
Installation:
8. Once the shaft is in place, lube the top portion of the shaft with G-070 trans fluid, then slide the top cover onto the shaft. Tighten the two 8mm holding bolts (with 13mm heads).
Is there a need for a gasket between the transmission body and the shifter tower?
Old May 18th, 2019, 11:42   #53
Yourbuddysatin
Rtv or Honda bond is what I use on everything.
Old May 18th, 2019, 11:46   #54
BakoTDI
BakoTDI's Avatar
Perfect! Thank you!
Old May 18th, 2019, 12:16   #55
Yourbuddysatin
Yes sir
Page generated in 0.15811 seconds with 11 queries
[Output: 95.53 Kb. compressed to 81.18 Kb. by saving 14.34 Kb. (15.02%)]
