I just bought a 2005 Jetta TDI, (1oo horse, 180 torque) and I need to know if there is any good performance (known and proven to work) uprgrades. Mechanical or electric, for speed, acceleration and handling.
The most basic upgrade will give you 130 HP and 245 lb-ft of torque. You have to pull your ECU out (easy), send it to him in PA, and then reinstall it and possibly enter a code with Vag-Com to satisfy the immobilizer. Make sure you know someone with Vag-Com ($329 from Ross-Tech), or buy your own before doing this, unless Jeff says you don't need it.
The performance increase with this upgrade (ECU reprogramming) is VERY noticeable to say the least.
What about bigger injectors.. I have heard that doing performance upgrades causes the clutch to slip on manual tranny's. Something to keep in mind. Might have to upgrade the clutch as well.
The rocketchip is great for increased performance. I have it on my 04 Jetta and have not had any issues with it. Bigger injectors is still fairly new on the PD's and I have heard that it is a lot harder to switch then the older TDIs.
Dan
How does your Auto Transmission seem to be holding up since the chip install? Any change in shift points or anything unusual? I know after I supercharged my 99' Toyota Tacoma (Auto), it seemed to slip and shift really funky.. I had to change the way I drove it..
Also, did you take any preventive measure to insure from over-boosting? How many miles have you put on your car since the chip upgrade?
The tranny is holding up just fine. I haven't had any issues with that. I have around 10k miles on now since I have been chipped.
I have added a boost valve to keep me from over boosting. I have overboosted once before the valve. I have also installed a boost gauge so you can set the boostvalve properly. You can get the valve from www.boostvalve.com
I HAD the same car as you. It is far from a stock looking or driving car now.
We carry a full line of tuning boxes for All VW TDI'S as well as the PD engines. Horsepower and torque are increased by up to 30% without any increase in Turbo pressures. The install takes less than 1 hour without any interuption to the wiring harness or ECU. The modification is also not detected using the VW test equipment. The gains are amazing and are achieved strictly by altering fuel mapping. Developed, manufactured and tested in Germany and comes with a 3 year warranty on all products. [image]
The tuning box method has been tried before by a club member (deathengine) and he found that it made lots of power at first, but then the ECU slowly dials back the fuel to normal (probably with help from O2 sensor readings). Does this tuning box do anything to address that issue? It probably works on European PD's, but they don't have an oxygen sensor if I recall from previous discussions on this subject....
We have had no problems or complaints with power backing off over time here in North America. I have several local customers with PD engines and have had no complaints at all. If you have any further questions please feel free to ask. This was a dyno test done on Tuesday at Kinetic Motorsports with a 05 Jetta PD TDI with no other mods except the Dieseltuning module. Joe [image]
