Old April 24th, 2018, 06:30   #1726
denismccar
Default Scan
4 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 882 /min
Torque: 60.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 23.4C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 882 /min
Torque: 60.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 23.4C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Freeze Frame:
RPM: 882 /min
Torque: 60.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 23.4C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 882 /min
Torque: 60.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 23.4C
Bin. Bits: 10110000
denismccar is offline   Reply With Quote
Old April 24th, 2018, 07:54   #1727
Diesel-Dan1
TDI(s): 2002 Jetta
Fuel Economy: 48
I just swapped in a good harness from my wrecked car. Still was getting MIL on cyl 2 glow plug. All plugs ohmed out within spec. Replace with Bosch plugs. Code gone. Take that for what it’s worth.
Bosch 80028/0250202022 Duraterm Glow Plug https://www.amazon.com/dp/B000CF5U76?ref=yo_pop_ma_swf
WRECKED: 2002 Jetta TDi, 5 speed, 17" wheels, rebuilt head, VNT17, PP764's and Malone Stage 4
2002.5 Jetta TDi, 5 speed swap, unlocked ECM with small tune, Studs, Stage 2 cam. Slowing working stuff over from wrecked car.
Diesel-Dan1 is offline   Reply With Quote
Old April 27th, 2018, 13:56   #1728
denismccar
Default Glow plug relay/control mechanism testing
It seems the issue is that no power is going to the glow plugs with the coolant sensor off....fuse on battery is good.... I rechecked the wiring on the new harness and it that looks good (all the cable colors match perfectly)....I checked that there is continuity from the spliced in connections to the new harness (in case new harness had a break) So, I guess the relay/control mechanism is next possible issue.... other than buying a new one, is there a way to check the current relay/control mechanism.
Old May 16th, 2018, 10:55   #1729
denismccar
Swapped out control/relay from my other tdi (same part number) and still no power to GP's. Control/relay works on other car with no codes thrown.
Old May 16th, 2018, 12:49   #1730
Vince Waldon
Vince Waldon's Avatar
Glow plug fuse on top of the battery is OK? Tested with a meter as opposed to an eyeball?!
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is offline   Reply With Quote
Old May 20th, 2018, 22:15   #1731
MrAsano
Fuel Economy: 40mph
Please help me...I have the standard glow plug error with my check engine light.
Things I have done to fix the issue.
1. Change the 109 relay under the driver side steering wheel
2. Changed my glow plugs 2 times
3. Installed a new glow plug harness (2 wire)
4. Used DeoxIT on the glow plug harness
5. Checked the fuses in the fuse relay box that sits on the battery.
What else am I missing? I have a 99 TDI that was made on October 1998. It just seems like I'm chasing my tail with this.
MrAsano is offline   Reply With Quote
Old May 26th, 2018, 17:08   #1732
denismccar
Default Glow Plugs No Power
Yes, tested all 3 fuses with meter. Also checked contacts are clean and good...
Old June 25th, 2018, 13:54   #1733
denismccar
Well, problem solved.....caused by my own hands lol. So, when I replaced the GP Harness instead of 'splicing' the new wires into the harness, I cut them and connected directly which obviously meant no communication was happening to the ecu. Once I went back and put it so that it was a splice in, all worked out (other than it taking forever to clear the 'Comprehensive' in Readiness. I feel such an idiot.
Old August 5th, 2018, 12:16   #1734
Dieselista
Dieselista's Avatar
Great post thanks. It seems the link to the original post is no longer working.
Original code P0671, #1 glow plug. Worked on this today, tested resistance at each plug, all exactly 1.2 ohms. Unplugged coolant temp sensor, checked voltage at all wires for plugs, all 12.4. Initially I got no voltage at the harness, I then unplugged and plugged back in the 10 amp engine fuse at the fuse panel in the cab, and then all worked. The fuses on the battery are all tight and clean and have good voltage on both sides. Assuming this fuse may have been loose or crusty? I cleaned and applied a little dielectric grease.
I then went to AutoZone to get the code cleared, to see if I'd solved the problem. They said they aren't allowed to do this anymore, went to O'Riely and Advance, both said the same thing, not allowed to do this. They suggested going to the dealer (I can imagine how that would go, I had a new Jetta a few years ago and it was agonizing even for warranty repairs) or an auto repair shop.
Can I buy a scan tool or connection for my phone and an app that will allow me to read and clear codes? If so which one is preferred?
www.stevedmarine.com
Dieselista is offline   Reply With Quote
Old August 5th, 2018, 12:19   #1735
Dieselista
Dieselista's Avatar
PS
I now have a new code, coolant temp sensor, from unplugging it to test the glow plugs. That's obviously not a fault, but it too needs to be cleared.
Old October 23rd, 2018, 04:35   #1736
k_pt
k_pt's Avatar
TDI(s): VW MKIV TDI
Do you guys have any solutions for glow plug wiring harness? Is there any way I can get the leads separately (like this) And make my own harness?
Follow me on some mechanics works https://www.instagram.com/kptgarage1986/
k_pt is offline   Reply With Quote
Old October 23rd, 2018, 13:40   #1737
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Search "make glow plug harness" with this nice user contributed search engine (gogl)
VW TDI Search Engine
BobnOH is online now   Reply With Quote
Old January 16th, 2019, 10:22   #1738
iluvmydiesels
TDI(s): AHU
Fuel Economy: mk3 ~43mpg
a little help, pls, wingnut,guys.
have a mk3. its my coolant glow plugs. havent worked for sometime. today i went to test them. its 40dg F out. i turn on the ignition, no voltage at any of the 3coolant GPs. turn the car on, its dead cold, or been off for more than an hour. again i can get no voltage reading here(any of the 3). gotta try to look up in the manual fuses and relay(s) to check. i have 3 of those GPs on order, rather expensive. yet not getting any volts at GPs would be the first thing to solve. either that or hook-up my vag-com to be able to activate.
i dont think there is even a notation of them in my coolant section of my manual.
was looking at some of this thread, man its sooo long, nice on that! just a little help, pls, may get me going. thks.
or even that kiss-of-death wire harness connection right by it, the head.
small fleet of mk3 tdi
have exp on mk1&2, idi
other vw interests
iluvmydiesels is offline   Reply With Quote
Old January 16th, 2019, 10:56   #1739
BobnOH
not-a-mechanic
Don't know if there is much on the coolant GPs in this monster thread, but most of us just let it go, they seem to do very little. Perhaps it's more of a problem with the AHU.
Old January 16th, 2019, 11:58   #1740
iluvmydiesels
TDI(s): AHU
thanks for the link. nice one.
the vwdiesel.net post, link showed me a lot.
no luck, yet. so i found the fuse box. was wondering which was which. checked both, the one on the firewall, its said this is the coolant glow plug box. cleaned both. (the other is by the coolant jug. it has a 20a fuse in it, and the other fuse opening looks like a blank??). (the firewall box>)so this one, i have one wire coming into the fuse, and the fuse secure. i have 14+ volts here. (and the same voltage reading on the other side connector of fuse, so fuse is good) a lower big wire. no current here. a smaller lower wire, slip connected on, nothing here. and the 3 prong connector in the middle(bottom).
so to try to trick the system i unhooked a few connectors. i think the coolant connection in the middle of the hose going to the top of the radiator is for A/C operation, the coolant main sensor i have is right by the head, the main front flange, unhooked this, no help there, im not sure of all this sensors operation. its 4 prong. im not 100% sure where the intake ambient air temp sensor it. i unhooked the one coming out of the air (filter)box. i believe its a maff or mapp sensor.
so looks like i have to have a shop take a look at it. its gotta be the reading going to the 3 prong bottom fuse box connector.
other vw interests
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Page generated in 0.18828 seconds with 10 queries
[Output: 127.98 Kb. compressed to 106.45 Kb. by saving 21.53 Kb. (16.82%)]
