Old January 20th, 2019, 08:11   #16
Mongler98
Originally Posted by joetdi View Post
Apparently you don't know what full fielding an alt does, with respect to the reg as you don't need a fully charged battery.
A guy next to me was working on a like vehicle as mentioned here. He measures about 9.6 volts. So based on Mongler's statement above he puts a OEM alternator on the car. He measures 9.8 now. So, it must be bad one right? So, he puts another OEM on and now he's really close to 10 volts.
What you think was wrong with this car and how did he find it.
And no it wasn't another bad alternator.
DO tell!
sounds like a blown fuse, possible short on the wiring harness, possibly a parasitic draw of crazy proportions! i don't have a clue as these things are difficult to tell even with the proper equipment, it takes a qualified and specialized person to be present at the car with a good set of tools and know how to determine odd issues like this. You cant expect anyone on the forums to say " this is the problem" and it be that problem 100% of the time. But i can say that 99.9% of the time when you have bad voltages from an alternator and it was tested properly that the diode is bad.
Old January 20th, 2019, 08:31   #17
scooperhsd
Originally Posted by Ol'Rattler View Post
The OP has 9.4 volts charging voltage. Is there some magical test equipment that would tell him why? What would this test equipment draw? a picture of Mr. McGoo?
Exactly, you should be measuring 13V - 14V at the battery.
2000 Red NB TDI, 370,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old January 20th, 2019, 12:55   #18
joetdi
Look fellas, this guy implies that the alternator light is not on in his first post. If there is an open circuit in the wire to the light the alternator is not going to charge the vehicle and the battery will go dead. And his voltage will drop.
Or do you think he should risk replacing the alternator first and THEN see if the wire is open.
Ya, it is a simple system but why am I the only one that seems to see this. He needs to confirm that first and then there are other possible causes to.
He needs to turn the key on see if the battery light comes on and if not, ground it at the alt and see what happens. If the light still does not come on you got a problem. And it won't be the alternator.
joetdi is offline   Reply With Quote
Old January 20th, 2019, 13:08   #19
jayb79
Well, it seems that this "emergency" is not all that important to the op as he has yet to reply to his "emergency". So, for now, I would just let it go until he replies to all the excellent feedback he has so far.
01Golf(425k) 50-52 summer mpg, 2013 Mustang V6 28-30 summer mpg, 2016 F150 RCSB 2WD 2.7L ecoboost 25-27 summer mpg.
jayb79 is offline   Reply With Quote
Old January 20th, 2019, 15:14   #20
Mongler98
Because testing the the voltage output of the alternator will tell you if that is the issue. I dont care how many dead batteries or open circuits are in the car, the alternator is either putting out 13ish volts or it is not.
Old January 20th, 2019, 15:48   #21
joetdi
That's how much you know.
Oh my, I hope that an open ground circuit to this alternator light is not this guy's problem because if it is, he is going to put an alternator on this car and be pissed.
It's not just you, there are a few others here that seem to think that the only thing this can be is a alternator. If you guys don't think that an open ground for the light can cause the problems he's having I can't help ya. The alternator on that car works the same as any other over the last 50 years.
OIL HAMMER, HELP, I'M NOT GETTING THIS ACROSS TO THESE GUYS THAT THIS COULD BE AN OPEN CIRCUIT, IT COULD BE OTHER THINGS TO BUT, THEY WANT TO PUT AN ALTERNATOR ON THIS CAR BEFORE CHECKING THIS AMONG OTHER THINGS THAT COULD CAUSE THIS. THEY ALL SEEM TO AGREE THAT THE ONLY THING THIS CAN BE IS AN ALTERNATOR. MAYBE THEY WILL LISTEN TO YOU.
I done with this.good bye.
Old January 20th, 2019, 18:03   #22
Mongler98
I, and most others here, never actually said to replace the alternator. We said to test it with a multimeter and to diagnose what’s going on and how OP can go about doing it.
While you are right in what you’re saying about an open circuit to the cluster light, what you are not understanding or are blindingly raging against is the fact that you can in fact disconnect the alternators 3 or 4 pin wire harness, and for that matter ALL THE WIRES even to the battery, start the car, and test the output of the alternator. THIS is how it is done at auto shops including autozones alternator testing rig. It simply and ONLY measures the output voltage and its sign wave and gives it a load draw amp check for kicks.
If OP just puts his probe leads on the battery and gets 9 some votes, sure it can be a few things, we check for the most common and work back from there.
I hate throwing money at a problem; you should know that if you have read my posts or my threads.
What you seem to do is argue about a point that nearly none of us have made. I did say that parts with warranties are great in the right application but I rather go EOM but I did not say to just buy a new part.
You are getting across plenty to all of us, and it feels like your just being a, well you know.
And as for the last 50 years, well most cars back then ran on generators, not alternators. And when alternators did come out to the world, it was back in the 1960's and they were NOT controlled like they are now and I can tell you that all the OEM alternators from the 70's (well in the cars I have owned and worked on) No they only had a ground and a charging wire. I’m sure some may have but you’re kind of going off the deep end here with exaggerations and ALL CAPS. No need to yell dude.
Glad to see you’re done, as am I, and so should this thread because OP has yet to respond. I’m sure he went to AutoZone and got a new part and it fixed it and he abandoned this thread. LOL
Old January 21st, 2019, 14:35   #23
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Dead cell. This is why we test them the way we do. Voltage gives really good clues, often all you need, but it's not conclusive.
BobnOH is online now   Reply With Quote
Old January 21st, 2019, 18:54   #24
[486]
TDI(s): 02 golf ALH
good choice, arguing with mongler is wasted effort, he will not learn anything
[486] is offline   Reply With Quote
Old January 21st, 2019, 19:05   #25
joetdi
Ya, I don't why I do. He will tell you he never said something but you look back in his post and there is.
I think if you told him that if someone falls in a hot tub full of water they would come out wet but, he could post 3 paragraphs telling you why this person would be dry.
Old January 21st, 2019, 21:06   #26
Mongler98
you still have not told us what it was, and im not wrong. boss alternators and for that matter any alternator that i know of (in working order) will output 13-14 volts regardless if there hooked up to something or not.
prove me wrong or step off my back.
Also it seems you want to start stuff here. you guys should be messaging in PM, NOT in forum posts about any user here. its not nice, and definitely does not help the thread.
What at all in this thread am i wrong about? Show me, if i am, i will admit it 100% and eat my humble pie.
Old January 22nd, 2019, 04:26   #27
Ol'Rattler
Ol'Rattler's Avatar
To funny. Help Mr. Wizard!!!!!! No one, even me, understands what I'm saying because I can't read and understand written English!!!!
I know it has bin implied that above all else the problem should be fully diagnosed, but I just can't believe that is what the other posters meant.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Battery / generator light on, alternator not charging, battery holds charge Keven VW MKIV-A4 TDIs (VE and PD) 16 December 12th, 2013 14:22
Battery not charging NeilO TDI 101 8 June 6th, 2011 22:26
Battery Light Blinking Battery Not Charging, Hard To Start hardmeat VW MKIV-A4 TDIs (VE and PD) 3 November 2nd, 2009 16:56
Battery not charging AARodriguez Corp. TDI 101 2 July 2nd, 2009 14:04
charging battery? jjtkcep TDI 101 6 June 28th, 2009 13:01
Page generated in 0.19206 seconds with 11 queries
[Output: 117.16 Kb. compressed to 99.71 Kb. by saving 17.46 Kb. (14.90%)]
