Old January 15th, 2019, 17:34   #1
ThunderstundAnchor
TDI(s): Golf 6 1.6
Default Blown out fuel injectors
I thought I’d post here and ask for advice. Earlier tonight I got stranded on the highway with two fuel injectors blown out of their holes.
I’ll try and tell the full story.
I bought a Golf 6, 1.6l 2011 model 3 months ago. Drove it and saw that the fuel economy was quite poor, and it would make a ticking noise at low rpm. Living in Kosovo we are used to having poor diesel quality and I left it at that. However it became a concern why my Particle Filter started getting clogged up and the warning light coming on at least once a week. In addition to that occasionally white smoke would come out of the tail pipe (unburned diesel).
I sent the car for a check up when the range displayed for full tank was just 520km. I had a Golf 5, 1.9 and I’d get easily 900km in a full tank. The mechanic diagnosed the problem as being a faulty injector. I sent the injector for a checkup/cleanup and it came back fine. Later on the mechanic advised me to put a type of oil to clean the injectors into the tank. I did that drove for 20km the engine starter ticking hard and then a bang sound came and I stopped the car seeing that I had blown an injector.
I did some research and the oil he put is a type of engine oil for chainsaws. I have used the same oil in all my previous cars with no fault, I had Golf 2, 1.6, Golf 4 - 1.9 and Golf 5 - 1.9.
Now the car is at the shop with a full tank of fuel mixed with 2L of that oil in it and the mechanic insisting that it wasn’t the oils fault!
Should I just go to another one and have the tank drained or should I trust him in fixing the car.
Links:
Oil: https://imgur.com/gallery/SnKVxBm
Blown fuel injectors: https://imgur.com/gallery/do4uSwH
ThunderstundAnchor is offline   Reply With Quote
Old January 15th, 2019, 17:57   #2
KLXD
I doubt the oil caused an injector to blow out of the head.
Who reinstalled it after the testing? I suspect he caused it to blow out. Either overtorqued the clamp and broke the bolt or left it loose.
Is the bolt broken or did it back out of the hole?
Current: ’02 Jetta, Auto; ’98 Jetta, 5 Spd; ’98 Dodge, 5 Spd, SB, 4x4; ’84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): ’85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: ’85 Mitsubishi PU, 4D55T; ’81 Rabbit, 1.6; ’80 Dasher, 1.5; ’79 Rabbit, 1.5
Old January 15th, 2019, 18:05   #3
iluvmydiesels
TDI(s): AHU
Fuel Economy: mk3 ~43mpg
idk, just a possible opinion, as an 'oil' in a newer model like this, along with seemingly faulty injector service, the oil can increase combustion pressures, helping to blow out an already mis-seated injector. i didnt think you could even still think of using an oil like that in newer diesels, thats an old IDI trick, usually for pump lube, even inj lube. thought that oil fouls mk3 systems and newer. im not 100% sure, for the new and newer diesels if you still use purge. i know we do. (a3).
small fleet of mk3 tdi
have exp on mk1&2, idi
other vw interests
iluvmydiesels is offline   Reply With Quote
Old January 16th, 2019, 11:59   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
If you put the 2 L of 2 cycle oil right in the tank, not empty, it's possible it did something odd running straight. I just don't know, lots of folks have used that oil as a fuel additive with no bad results.
Old January 16th, 2019, 16:50   #5
turbobrick240
turbobrick240's Avatar
The two stroke oil had nothing to do with the injectors blowing out. It could contribute to your clogged DPF though if you were using it for a long time.
Old January 17th, 2019, 16:00   #6
Ol'Rattler
Ol'Rattler's Avatar
Agree 1000%. Also 2 stroke oil does nothing to clean injectors.
Improper injector installation and/or reuse of the TTY bolt caused the TTY bolt to break.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old January 18th, 2019, 03:45   #7
iluvmydiesels
TDI(s): AHU
it looks like OP put 2L of this oil in a ?full tank?, thats a hell a lot of this oil, i think for a full tank ~10gals it was ~2oz of oil. 2L is going to cause a lot of problems, and if you use it more than once.
other vw interests
Old January 22nd, 2019, 20:49   #8
ghohouston
ghohouston's Avatar
Fuel Economy: 40 Mpg
Sounds like the cause has already been stated, either overtorqued (broken bolt, hold down, or both) or undertorqued injector hold down bolts that came lose. The ticking sound you heard was compression leaking past the injectors. Kind of hard to tell from the picture, but seems like the hold down on #2 is turned, but im not familiar with this particular engine, and how the injector hold downs are oriented.
2001 Silver Jetta Sedan TDI 5 Speed,3" Kerma turbo back straight pipe
Allard EGR Delete
Bosio DLC 764's. 1997 Ford F350 CCLB 7.3 Powerstroke Diesel ZF5, straight piped
ghohouston is offline   Reply With Quote
Blown injectors or burned up valves? Clevenger VW MKIV-A4 TDIs (VE and PD) 44 December 16th, 2018 20:48
Blown motor, Injectors OK? Bob702 VW MKIV-A4 TDIs (VE and PD) 6 January 2nd, 2013 18:32
FS: common rail fuel pumps, injectors and fuel rails pghvdubguy95 Private TDI Items for Sale/Wanted 6 December 12th, 2012 19:03
Bad Fuel Injectors, Nozzles or Mexican Fuel?? Yaco TDI 101 6 October 28th, 2006 07:30
(2nd) blown turbo, blown engine, no warranty - Wett caused, says VW Jeff Strachan TDI Power Enhancements 110 November 16th, 2000 16:30
Page generated in 0.17647 seconds with 11 queries
[Output: 87.55 Kb. compressed to 75.44 Kb. by saving 12.11 Kb. (13.83%)]
