Old January 15th, 2019, 10:38   #1
fluxcore
TDI(s): 06 jetta tdi
Default 06 Jettta TDI fuse panel c top row no power, there
3 hot leads below 1 ground up top. should there be 4 hot leads there and why does the ground go to the relay panel, and i can't find power on top row. thanks
were much.
fluxcore is offline   Reply With Quote
Old January 15th, 2019, 11:03   #2
SilverGhost
SilverGhost's Avatar
huh? SC fuse panel in the dash? Do you have the back off and looking at cables?
Jason
SilverGhost is offline   Reply With Quote
Old January 15th, 2019, 11:22   #3
fluxcore
yes no back on it and i described the cables i thought i described it. i don't know why there no power on top and ground going to relay panel i think it works with key. thanks
Old January 16th, 2019, 09:52   #4
SilverGhost
What color is the wire you called a ground? Are you looking at the Triangular shaped fuse panel on the end of the dash?
Jason
PS; a picture of what you are looking at would help A LOT.
Old January 17th, 2019, 09:38   #5
fluxcore
Jason
it black, please inform me on how to upload a picture
Old January 17th, 2019, 10:54   #6
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Short version:
Log in again at pics.tdiclub.com
Select Upload button, follow prompts (check your file type)
At the end, harvest the url to use as a link for your post
Note there are 3 sizes with separate urls For large data use the thumbnail, it shows the full size when clicked.
Or more complete instructions in my signature.
Old January 18th, 2019, 11:58   #7
SilverGhost
Well, there is your first problem. That's not ground. A brown wire is ground. On a VW red are battery positive, black are switched positive (IE: ignition), and brown are ground.
Jason
Old January 27th, 2019, 07:03   #8
fluxcore
Jason
Thanks Jason I'll check today. I know it good to plug then there relay panel?? may need a good scanner Thanks
Old February 5th, 2019, 11:58   #9
fluxcore
Hope this help the car has no,key power, dash light or wiper action? do i need a expert electrical tdi member, scanner. thanks Jim i think i found problem on j317 power supply relay terminal 30,b+( in Bentley expensive book i tested relay panel socket I picked two 12 volt and 1 12 volt thee 4th hole i got 0. so i used track tool see what i could find. i din't pick up any on the side with all the wires, but on black side of plastic, the track sensed the wire up about 2" up. then it stopped, think found the problem, and what i do with it!!
Picture of an 06 TDI Jetta Fuse box Panel dlm308rem South Eastern USA 1 August 10th, 2015 20:52
Battery Top Fuse Panel wincharger TDI 101 0 August 11th, 2011 11:53
Battery Top Fuse Panel wincharger TDI 101 0 March 16th, 2011 15:41
Fuse Panel Diagram Jetta TDI '06 Rival12 VW MKV-A5 Golf/Jettas 3 May 7th, 2006 02:11
Wanted: Fuse panel from battery top Wingnut Private TDI Items for Sale/Wanted 1 June 23rd, 2004 23:58
Page generated in 0.16080 seconds with 11 queries
[Output: 91.18 Kb. compressed to 77.82 Kb. by saving 13.36 Kb. (14.66%)]
