Old January 14th, 2019, 02:40   #1
lthomsen
Default Skoda Fabia mk2 -- Airflow direction not working
Hi.
The car is a Skoda Fabia mk2 from 2007 1.9TDI with aircondition.
Last week I got my blower engine replaced.
A few days later I found that the direction knob on the heater system wasn't working.
Furthermore no air is pushed through the center console vents and the side-to-side manually adjustment is stuck.
Everything else is working fine.
It seems that the air is distributed equally between the wind shield and cabin vents regardless of the air vent direction setting.
I did not notice this before the blower engine replacement, so the problem might not be related.
I called the mechanic who did the blower replacement and he was able to do the replacement without having to disassemble the center console.
Any ideas/thoughts on what might cause the problem?
lthomsen is offline   Reply With Quote
Old January 14th, 2019, 12:29   #2
lthomsen
Default ****update
The problem is resolved.
In case anyone is having the same problem I will just describe the debugging and solution.
1. OBD2 readout -- no fault codes, so I figured it could be a mechanical issue.
2. Removed the center fans and once I tried to move the fan vent cable it felt loose it the other end.
3. Removed the pollen filter and the cable was somehow disconnected -- managed to attach it with a screwdriver.
4. Hurra
Skoda Fabia mk2 1.9TDI High Revs lthomsen TDI 101 15 April 10th, 2018 03:58
Skoda Fabia on track devonutopia TDI Power Enhancements 8 May 5th, 2010 16:07
Skoda Fabia vRS AMGvRS Other TDI/Diesel Picture Gallery 1 January 2nd, 2007 11:48
skoda fabia tdi chrisray Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 October 31st, 2005 08:49
310Nm on Skoda Fabia! GolfComfort VW MKIV-A4 TDIs (VE and PD) 3 March 6th, 2001 12:26
Page generated in 0.12251 seconds with 11 queries
[Output: 52.78 Kb. compressed to 48.66 Kb. by saving 4.13 Kb. (7.82%)]
