Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old January 12th, 2019, 09:53   #1
ally29483
Default AdBlue line, damage, Explosion?
I have a 2014 Passat TDI SE - day before Christmas Eve - Adblue error - first time seeing it - googled - filled vehicle (I was traveling, not near any dealers) - filled with Def....following reset - error went away. New Years eve - error again - drove to dealer - they replaced a sensor and took care of two recalls - that evening Adblue error again on full countdown...drove to a dealer again (closer to my hometown) and they said the previous dealer didn't replace fluid - when they fixed - drained the tank - they filled up - a day later - smoking at back of vehicle - could smell what seemed like fluid/exhaust burning.....error came back on again two days later - countdown again - but continued from previous countdown - took to dealer and told them about smoking - they opened the trunk and there was crystallization everywhere near refill area. They put vehicle on lift and you can see the pictures - not good. They said I apparently hit something?? Service manager texted me photos - Which I haven't hit anything - no speed bumps - potholes - but they say I hit something - knocked the line loose - major repairs possible and not covered under my warranty - of course. I call BS. But maybe I'm wrong? Two dealers have looked at the car and no one has mentioned this at all....https://www.flickr.com/photos/167490.../shares/51vp44
ally29483 is offline   Reply With Quote
Old January 16th, 2019, 09:33   #2
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Ask them to show you the damage that leads them to believe you hit something.
There should be visible damage somewhere (front bumper, subframe, maybe even on the injector itself). Something to back up their story of impact with something else. You should know what impact damage looks like. There HAS TO BE impact damage if they are saying you hit something.
Two, ask them WHY noone has ever mentioned it before. Call them out on their BS.
What sensor was replaced before? Did it require them to get under the car? Maybe THEY screwed it up?
Fixmy59bug is offline   Reply With Quote
2015 Jetta TDI SEL ADBLUE line leak BradfordTN Dieselgate - VW Group Emission Scandal 9 December 21st, 2018 06:06
Rats, wiring damage, AdBlue Heater failure White Passat VW Passat Family (NMS and B7) TDIs (2012+) 9 December 21st, 2015 05:39
BEW engine - block damage oil starvation - damage inspection kraftwerkturbo VW MKIV-A4 TDIs (VE and PD) 7 February 14th, 2015 11:32
Transmission Explosion brianrohr13 VW MKIV-A4 TDIs (VE and PD) 11 September 15th, 2014 07:21
**Oil Explosion!** Help! jek VW MKIII-A3/B4 TDIs 14 May 3rd, 2011 10:00
Page generated in 0.11287 seconds with 11 queries
[Output: 54.21 Kb. compressed to 49.98 Kb. by saving 4.23 Kb. (7.80%)]
