Old January 8th, 2019, 21:07   #1
Dadwagon
Default Weird wiper malfunction
Hello all, been a while since my last post- my 04 wagon is running great, its my daily driver with 420K! Only issue i have is when parked overnight, if rear wheels are not higher than front, i lose fuel pressure, starter has to crank forever before she starts.
Beauty of my situation is that my driveway is sloped, so i just back it in every night, she fires right up every morning. I tried the one way check valve, it helped, but did not completely solve. My guess is at some point iíll Replace the tandem pump, but Iím not in any hurry to do so..
Onto the question- on occasion, the mist function on wiper blades doesnít always single swipe like its supposed to. Instead, it will wipe continually, and i have to hunt with the wiper lever to shut wipers off.
Any idea if there is a fix for this?
Dadwagon is offline   Reply With Quote
Old January 14th, 2019, 18:32   #2
jetmech54
Fuel Economy: 7.02 L / 100 Km
there may be a connection issue between wiper lever and the slip ring on the steering wheel, I had an intermitten issue with my turn signal a while back, all I did was removed the lower steering wheel cover to expose the leavers and sprayed come electrical contact cleaner and it fixed the issue, it may work for your wipre issue.
jetmech54 is offline   Reply With Quote
Old January 23rd, 2019, 11:23   #3
tyberesk
tyberesk's Avatar
I had the same wiper issue and replaced the relay with one I bought on ebay for under 10 bucks. (It was OEM PN: 4B0955531E)
tyberesk is offline   Reply With Quote
Old January 25th, 2019, 06:04   #4
Dadwagon
Ahhhh, that makes sense, thanks! Is the relay located behind kick panel? Steering column?
Thanks again
Old January 25th, 2019, 06:13   #5
Tdijarhead
Up under the dash by the steering column, the largest relay in the panel with a big 377 on it.
Tdijarhead is offline   Reply With Quote
Old January 25th, 2019, 07:39   #6
Dadwagon
Ok thanks, i ordered the relay from Uro parts- will report back
Old January 29th, 2019, 13:47   #7
Dadwagon
installed new wiper relay today- work perfect now.
I'd say its worth the 30 minutes of time, and $25 expense.
Hope this helps someone else with same problem
wiper malfunction oshaggy TDI 101 0 March 16th, 2013 22:41
Weird wiper mxracer183 VW MKIV-A4 TDIs (VE and PD) 2 February 16th, 2009 10:30
Front wiper problem turns out to be rear wiper connection corrosion, so check yours laminated VW MKIV-A4 TDIs (VE and PD) 2 June 12th, 2008 20:41
windshield wiper malfunction Goldie VW MKIII-A3/B4 TDIs 6 December 3rd, 2007 06:58
Intermittent wiper malfunction? dr_p TDI 101 3 September 13th, 2006 14:59
Page generated in 0.14503 seconds with 11 queries
[Output: 79.00 Kb. compressed to 68.82 Kb. by saving 10.18 Kb. (12.89%)]
