Old January 2nd, 2019, 21:30   #1
boodles
boodles's Avatar
Default Quick question about Side View Mirror
Hey, so, someone dinged my MKIV (eyeroll), and I just have a quick question.
The car itself is fine but my driver sideview mirror is now loose? Not the glass or the attachment to the door- the area where itís meant to roatate/swivel just kind of spins and swivels uncontrollably now.
My question is pretty simple and Iím only asking because itís -10 and snow storming here.... can I fix it or do I have to buy a new mirror? Really donít want to start taking it apart just to find out thereís no hope and hen have to put it back together until I get a new one.
Also some people here think my carís a ďjunkerĒ. Itís not... if youíre not going to answer this question donít post. Thanks.
boodles is offline   Reply With Quote
Old January 2nd, 2019, 21:35   #2
STDOUBT
STDOUBT's Avatar
I didn't know they had heathens in Canada
Sorry, 1st Amendment FTW
2003 Jetta TDI 1.9L 5-speed
Search Tip: search this site best by using Bing: tdiclub topic
STDOUBT is offline   Reply With Quote
Old January 2nd, 2019, 21:38   #3
boodles
boodles's Avatar
Well you don’t need to be a jerk for no reason. Answer the question or piss off. Like honestly. You don’t need to come here just to literally be an adult cyberbully.
Old January 2nd, 2019, 21:40   #4
drucifer
Junker or not the mirror not being able to adjust is a safety issue. get another assembly from the junkyard.
drucifer is offline   Reply With Quote
Old January 2nd, 2019, 21:42   #5
STDOUBT
STDOUBT's Avatar
OK, I felt bad, and found you a fix. See post #8 here:
http://forums.tdiclub.com/showthread.php?t=300372
Apparently, the hinge crumbles over time.
Old January 2nd, 2019, 21:50   #6
STDOUBT
STDOUBT's Avatar
I thought I was being funny. But really, as an adult you should never say "cyberbully" and actually mean it as a serious thing. Protip: Anonymous people on the internet shouldn't be able to hurt your feelings. If they do, it's because you give them that power. Toughen up a smidge.
Whatever answer I gave, joke or not, I knew a helpful post would come along for you eventually. You're welcome here. We welcome you. But this site has it's own rule makers, it doesn't need another one.
Old January 2nd, 2019, 21:58   #7
boodles
boodles's Avatar
drucifer- the mirror is still attached and works just fine as long as I adjust it by hand when I get in. It’s not like there’s no mirror. I’m going to have it fixed, hence the post. What I’m wondering is whether I can fix my mirror for $10 or if I have to spend $100 on a new one. But thanks for not reading the whole post.
STDOUBT- thanks for the post, that honestly sounds like something I have to do at my parents place, which means something they’ll want to do, which inevitably means something that will end up screwed up. Plus I loose the ability to adjust the mirror... if that’s my only option I think I’ll buy a new one which kind of sucks. Cyber bullying is a serious thing, and the last post I made here I felt seriously attacked because of the car I drive and my inability to afford a new car. To be honest the people here are sometimes very helpful, but sometimes they’re very rude and ignorant.
Old January 2nd, 2019, 22:06   #8
STDOUBT
STDOUBT's Avatar
boodles,
I drive the same car as you. I'll just say it: Your car is awesome!
I do second the idea of finding a junkyard replacement. Very economical.
And I hear they're pretty easy to remove and replace. For sure there's a thread on here with the details. Another protip: The best way to search this site is on google or bing with your search terms pre-pended by "tdiclub". HTH
Old January 2nd, 2019, 22:16   #9
boodles
boodles's Avatar
The car has 310k km on it and needs a handful of repairs. Literally everyone I talk to thinks I should scrap it instead of put money into it. Honest to god the car runs amazing for how it was treated before I owned it, and it’s just taking me some time to catch up on small repairs that should have been done sooner that are now a little bit larger. Even still, these are still cheaper repairs than the monthly cost of a new car and why would I buy another used car when this car is now half new.
I want to pull a driver side seat out of a junkyard too so might as well do both at the same time. Going to pull he car apart- might as well pull the whole car apart lol
Old January 2nd, 2019, 23:57   #10
drucifer
Expand your budget to 15 or 20 bucks. Your entire
post included something about not wanting to be out in the cold and snow. Imagine that. lt gets cold in the great white north. Also there was something about people telling you to junk your car. I don't know if that's people here or people you know. If you can't find a good drivers seat get two passenger seats and use the foam and cover on your driver's frame.
Lighten up, people are here to help as well as the search button at the top and the sticky thread at the top of tdi 101 that leads to a custom Google search combining results from 5 or 6 forums.
Old January 3rd, 2019, 08:14   #11
steve6
The swivel point is aluminum rubbing on aluminum, aluminum oxides and crumbles, this is what your pivot point has done when it was nudged. There is plenty of scrappers for vw parts that can send you a replacement, if you are in Ontario I can give you some specific places to check, otherwise wrecking yard is probably your best bet. Over the years I have acquired two spares that hang in my garage, because well, in our climate the engineering of these mirrors kinda sucks with the aluminum crumbling. You may be able to secure the pivot point to keep using the mirror safely but its probably a lost cause, you would not know unless you take it apart and look it over, but for that kinda effort go get a replacement for $30-$60 and just replace it.
steve6 is offline   Reply With Quote
Old January 13th, 2019, 20:24   #12
6oh
hey Boodles..... in Toronto, i've had both of my old 01' TDI mirrors knocked off by drunks or bike riders, when coming back to my car, that aluminum crumbles pretty much into white residue. The wire harnessing stayed intact, so in my winter rush (and a fully ghetto way) i have just gorilla glue'd it back on and a nice piece of trim tape to clean it up, no one knew the mess it was.
That being said, I also helped a buddy get a new hinge at a local used VW parts place, and for $20 and fixed the mirror properly. Just a nuisance task.
6oh is offline   Reply With Quote
Old January 13th, 2019, 20:45   #13
mrfiat
Fuel Economy: 38.5 mpg (in town - trying to improve it)
I bought a new mirror on Amazon for around $40 and had it painted. Easy peasy.
mrfiat is offline   Reply With Quote
Auto Dim Rear View Mirror + Dip Side Mirror CrustyOreo VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 January 1st, 2019 04:49
Side View Mirror Repair RC VW MKIII-A3/B4 TDIs 3 May 25th, 2011 17:16
Side View Mirror Keeps Coming Apart PDJetta VW MKIV-A4 TDIs (VE and PD) 0 October 22nd, 2004 16:50
What is your side view mirror preference? Marit TDI 101 25 July 24th, 2004 19:43
Has Anyone's Side View Mirror Come Apart Yet? PDJetta VW MKIV-A4 TDIs (VE and PD) 5 November 29th, 2003 06:38
Page generated in 0.16290 seconds with 11 queries
[Output: 112.43 Kb. compressed to 94.29 Kb. by saving 18.14 Kb. (16.13%)]
