Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old December 13th, 2018, 21:43   #1
ItAintRodKnock
TDI(s): 01GolfTDi
Fuel Economy: 40 with lift
Default Mazda3- Headlight pulse on downshift.
So, my sisters car is doing something that i do not understand. Also, dont know much about her car in general...
Anyways, its a 2013 Mazda 3, 6 speed tranny.
I drove it tonight to bowling league and noticed when i downshift coming to a stop or maintaining speed on a hill the headlights pulse. Dim, Go back to normal, Dim, go back to normal. Not a strobe, but maybe half second intervals.
Running the AC(for more power draw) made no change in the interval rate, or the lumen output of this pulse.
She says she's noticed it for awhile. So, its not new, and she has not recognized any other electrical quirks. The battery is new, Alternator is, assuming, Original.
Any ideas?
I doubt ill be digging into the car to diagnose, but if it turns out to be fairly common, then maybe I'd tackle it.
Thanks for any inputs!
From FLA to CO!! 2001 Golf 4 door White: R520, Malone 2, McNally gauge, SB stg2E clutch, Panzer FMJ, FrostHeater, 2white2blue Moog 81055, Bilstein TC-s, homemade "$40 2 inch lift" Long time poster, now just a lurker.
ItAintRodKnock is offline   Reply With Quote
Old December 14th, 2018, 04:54   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Which engine is it ? There are three. The Ford derived 2.0L (Mazda calls it MZR, Ford calls it Duratec), the 2.5L version of that same Ford engine, or the Mazda Skyactiv 2.0L.
The charging system is likely the same for all of them, though. The ECU should control the charging output of the alternator. I would also want to make certain that the battery is the correct type and size for the car.
But it may just be a normal quirk of that particular car. There was a TSB for some about PCM reflashing, not sure if it applies to that car though.
Search for this:
TSB: 01-13-21
2012-2013 MAZDA3 - HEADLIGHTS FLICKER WHEN BRAKES ARE APPLIED
APPLICABLE MODEL(S)/VINS
2012-2013 Mazda3 vehicles (with SKYACTIV-G 2.0L and Halogen Type Headlights)
Chances are there have probably been a half dozen software updates for that car since it left the factory anyway.
oilhammer
www.cardocautomotive.com
Old December 14th, 2018, 08:00   #3
ItAintRodKnock
TDI(s): 01GolfTDi
I think it is the 2.5 i will to confirm
Battery: with the cold she started having issues, so i went to oreillys, he pulled up all the different ones the comp says are good for that car and i purchased the highest rating one. so, hopefully it the right size.. I'll look into specs for the proper battery and which one i did purchase her.
I'll figure out what motor for sure.
Assume you looked it up through google or another forum? thanks for taking that time, oilhammer.
Old December 14th, 2018, 09:23   #4
oilhammer
oilhammer's Avatar
Alldata and MOD are my primary resources. But the internet also may net some information.
A reflash may be the ticket. After Mazda's split with Ford, we can no longer do those here, although I think they still use a version of Ford's IDS software at least on something like that. That car is essentially a Focus that Mazda assembled, with a few of their own locally sourced bits.
oilhammer
Old January 18th, 2019, 03:00   #5
garreth5
TDI(s): jetta
This should fix your sister's car-- mazda3revolution.com/forums/2010-2013-mazda-3-skyactiv-discussion/43697-pulsing-headlights-tsb-13-21-a.html
garreth5 is offline   Reply With Quote
pulse....... fatbuck1911 VW MKIII-A3/B4 TDIs 8 October 29th, 2013 18:12
mazda3 they recommend regular oil clutch cargo General Automotive 27 September 16th, 2010 15:53
traded 08 mazda3 on 09 tdi jetta jcool TDI 101 0 April 22nd, 2009 11:06
Mazda3 vs Tdi Ben-Zion Petersen TDI Power Enhancements 15 October 31st, 2006 18:24
talk me into a tdi vs mazda3 rallysmurf VW MKIV-A4 TDIs (VE and PD) 31 May 30th, 2004 13:33
Page generated in 0.12580 seconds with 11 queries
[Output: 70.66 Kb. compressed to 62.64 Kb. by saving 8.03 Kb. (11.36%)]
