Old August 26th, 2018, 11:03   #1
mohawk69
Default Very effective headlight lens cleaner
This may have been mentioned before but fwiw.... Someone mentioned this elsewhere and a friend tried it and it worked just as stated. It takes all of two minutes and it's inexpensive. Find a product with the highest amount of DEET. I found deep woods off with 25% DEET. They had some with only 10% so check. Spray on and wipe off. I think if you do it when it's cool and out of the sun it'll probably work better since you can leave it sit for a few seconds. I intend to do it again when I have a little time and then I'll put on a coat of wax. Better and much easier than anything else I've seen.
mohawk69 is offline   Reply With Quote
Old August 27th, 2018, 11:50   #2
Namakan
Namakan's Avatar
I was going to try this several years ago but after a little more research I decided the 3M kit was a better option. See link below:
https://m.youtube.com/watch?v=AYmbBZntuY8
2002 Golf GLS TDI 5sp (mine) - Malone Stage 1, Ventectomy, Cupholder Mod, Frostheater, 2011 JSW DSG (wifes car - now gone), 2004 Jetta (gone)
Namakan is offline   Reply With Quote
Old August 30th, 2018, 19:40   #3
mohawk69
It's been 4 or 5 days and all is still well. I intend to do it once or twice again and then wash and wax the lenses. I'll try not to get any on the paint but isn't every VW over two weeks old devoid of any remaining clearcoat anyway?
Old August 30th, 2018, 19:48   #4
borntofli
Now that right there is funny.........
borntofli is offline   Reply With Quote
Old August 31st, 2018, 15:15   #5
POWERSTROKE
POWERSTROKE's Avatar
TDI(s): 2002 Golf
I have 7 Vws in my family. Ranging from 2-17 years old. Most toward the upper end of that spectrum with no paint problems.
It's kind of fun to do the impossible.-Walt Disney
POWERSTROKE is offline   Reply With Quote
Old August 31st, 2018, 15:18   #6
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
One member was putting high SPF sunscreen on every month or so. Anybody try that?
Old January 7th, 2019, 11:05   #7
stmark
I have a 2003 wagon with 200k on it. Live in WA state so not a lot of uv problems. I used the 3M kit on the lens, easy. Not a lot of clouding, mainly in front of the headlight bulb, probably from heat.? After the process, I notice there is dirt and streaks on the interior of the lens. Great. Going to take the bulb out and determine if I can clean the interior. ANyone else notice this? Is the lens only replaceable?
stmark is offline   Reply With Quote
Old January 7th, 2019, 12:34   #8
Lightflyer1
Lightflyer1's Avatar
IIRC there was someone who was selling glass replacement lenses and replacing them DIY.
https://www.vxtuning.com/shop/vehicl...iv-jetta-bora/
Seems there is a thread here too about how to remove and replace them.
http://forums.tdiclub.com/showthread...ght=glass+lens
Old January 9th, 2019, 08:24   #9
andreigbs
I've used a little baking soda and vinegar, works wonders.
Try it before you knock it
https://www.youtube.com/watch?time_c...&v=QWMJubLqnRw
2014 Jetta TDI // 20xxx miles // 39 MPG & 2014 GLK 250 // 88xxx miles // 37 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed
2004 Bora TDI // 146xxx miles // 42 MPG - sold
1997 Jetta TDI // 317xxx miles // 44 MPG - sold
1986 Golf Diesel // 224xxx miles // 48 MPG - totaled
andreigbs is online now   Reply With Quote
Old January 9th, 2019, 09:07   #10
KLXD
So you neutralize some vinegar with baking soda and rub that on the lens?
Looked better after but it wasn't clear. Just cleaner. I didn't listen to the audio so I don't know what he was claiming about the finished job.
My sister in law wanted to try it so I gave here an old '2 headlight to try. It was bad, even yellow, not just cloudy. Didn't do anything.
The outside of the lens is oxidized or broken down chemically. Only way to remove it is with abrasives.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old January 9th, 2019, 09:48   #11
andreigbs
Technically the baking soda acts as the abrasive, the vinegar is used only enough to make a paste. This is then rubbed gently onto the headlight.
It requires several rounds but it worked well for me. A coat of wax and buffing will seal it one you're done.
It's practically free to try and you won't hurt anything. Each headlight takes about 30 min to do properly.
Old January 9th, 2019, 10:39   #12
KLXD
Seems to me the baking soda reacts with the vinegar forming sodium acetate and CO2. Unreacted baking soda dissolves in the water the vinegar was diluted with in the bottle.
If you had an excess of baking soda so some didn't dissolve there would be a mild abrasive effect. But then why not just use baking soda and water and avoid the fizzy mess?
Again, the light in the video was not clear when he finished.
Old January 9th, 2019, 10:52   #13
andreigbs
Chemical reactions are as you state, no debate there. The idea is that he used just enough vinegar to make a grainy paste. You can also use water, of course, and other videos show that option.
The fizzy mess actually helps to lift the residue that you'll be removing from the lens as you rub it. Vinegar being the acetic acid it is, makes a pretty good cleaning solution albeit a bit stinky.
I was just sharing my experience that it does work, and quite well. The fact that it's basically free (since nearly everyone has these items in their pantry) is just a bonus. If one prefers to use water instead of vinegar, that is perfectly acceptable as well
The other thing I've found that works is rubbing compound, the kind used to remove light scratches and swirls from your paint. I think 3M makes some, as do other brands. It's a nice gritty paste that you patiently rub the lens with several times with a cleaning in between each session. For the record, I've used the power drill and special sanding kit option too; way more time consuming and you risk damaging the paint around the headlight if your drill control is wobbly at all. This manual method is a lot safer.
Old January 9th, 2019, 11:17   #14
Alchemist
TDI(s): '04 ALH Golf
Acetone is very quick and effective, but care is needed to keep it off paint or other plastic.
I've learned so much from my mistakes I'm thinking of making some more.
Equipped with VCDS and a hoist in a heated shop.
I was told I have every tool known to man.
Alchemist is offline   Reply With Quote
Old January 9th, 2019, 12:35   #15
tactdi
tactdi's Avatar
TDI(s): 2005.5 Jetta
I use Meguiars Plastic Cleaner #17 and Polish #10. I found a trick to coat the plastic lens with equal parts Mineral Spirits and urethane once cleaned and polished. Seems to help keep the lens from yellowing for about 10 months vs 6 months without the coat.
tactdi is offline   Reply With Quote
Headlight Lens N.CaTDI VW MKV-A5 Golf/Jettas 3 May 20th, 2015 21:50
Can I take the lens off of a headlight? jjcsnlynn VW B5 Passat TDIs 7 July 1st, 2014 14:18
Headlight Lens howe719 VW MKIII-A3/B4 TDIs 10 June 7th, 2010 19:04
Headlight lens MAXRPM TDI 101 10 June 17th, 2009 12:28
Headlight lens T.W. VW MKIV-A4 TDIs (VE and PD) 5 January 28th, 2005 17:23
Page generated in 0.20749 seconds with 11 queries
[Output: 125.79 Kb. compressed to 104.51 Kb. by saving 21.28 Kb. (16.91%)]
