Old August 23rd, 2012, 17:05   #61
JSWTDI09
JSWTDI09's Avatar
Originally Posted by Blue_Hen_TDI View Post
I just bought my ScanGauge, so I'm not as up to speed as some others. But, if you take a look at this link, it says that you can monitor four different catalyst temps: http://www.scangauge.com/support/xga...ansf-vehicles/
I guess the only real way to tell would be to play with a ScanGauge and compare these "catalyst temperatures" with the VCDS readings of the EGT sensors. These catalyst temps may (or may not) directly correspond to TDI EGT sensors. If anyone has a ScanGauge, VCDS, and a CR TDI, this would be interesting to know. I am not going to buy a ScanGauge just to find out if it works.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old August 24th, 2012, 08:52   #62
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
FWIW, I programmed the code for the second EGT sensor (fahrenheit) into an X Gauge and got no reading.
2011 BMW 335d - JR 2.8
Blue_Hen_TDI is offline   Reply With Quote
Old August 24th, 2012, 09:12   #63
TomB
Fuel Economy: 34 mpg on first tank
After watching all four this morning with my VCDS it looks like EGT 3 is the DPF sensor since a regen yielded a consistent 582C, 1079F temp.
2007 Jeep Grand Cherokee 3.0L MB Diesel
2012 Passat TDI SEL Premium Opera Red/Titan Black
2015 Audi A3 TDI Prestige S-line Lotus Gray Metallic/Black Leather
TomB is offline   Reply With Quote
Old August 24th, 2012, 09:20   #64
JSWTDI09
JSWTDI09's Avatar
According to the "Self Study Guide" (which could be in error). EGT sensor #3 is after the DOC and before the DPF and EGT sensor #4 is after the DPF which should get up to about 1200 degrees F. (600 C.).
Have Fun!
Don
Old August 24th, 2012, 11:21   #65
TomB
Have Fun!
Don
What I actually noted on #4 was a temperature of 487C 908F and consistently lower than the #3. **Edit after re-reviewing the #3 varies a lot while driving. The #4 is pretty stable, either 260C or 500C. I will run it again later today. **
Again, I have log file from VCDS if anyone knows how to share it here and wants to review it.
Old August 24th, 2012, 11:27   #66
JSWTDI09
JSWTDI09's Avatar
I just noticed that you have a new Passat. The study guide I have is for the CBEA and CJAA engines. It is quite possible that the sensors are different in the CKRA (Passat) engine. I have no technical information on this engine. You could easily be correct about sensor #3 being after the DPF, I just do not know.
Have Fun!
Don
Old August 31st, 2012, 09:34   #67
HeAvYfUeL
HeAvYfUeL's Avatar
Fuel Economy: Fuelly signature --->
So,
I have the Scangauge and a 2009 TDi so, I put in the Xgauge Bank 1, Sensor 1 as suggest in the first post.
Wonderful. Just what I was looking for. But now, I also wanted to see the temperature of my DPF so I can see when a regen is happening.
I'm supposed to have 4 sensors according to the self study guide.
But when I put in Bank 2, Sensor 2 I do not get any reading on the Scangauge.
Now I have changed to Xgauge to Bank 1, Sensor 2 and assume this is the DPF.
Any ideas on which sensor# in the guide is which sensor (Bank#, Sensor#) for the Xgauge?
Thanks in advance.
2009 Jetta Wagon Comfortline DSG ESP build 03/09 Graphite Blue
History:
2006 Golf TDI GLS/1992 Jetta 2.slow GL
HeAvYfUeL is offline   Reply With Quote
Old September 4th, 2012, 21:43   #68
tomo366
TDI Lifer
tomo366's Avatar
based on VWDUBTDI'S suggestion I bought a Scan Gauge II and installed it in my 2010 Jetta Sportwagen with the help of Compu85, it displays nothing in EGT or water Temp......I have tried several times as Did Jason out at the Fest still nothing ! any suggestions??
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old September 4th, 2012, 22:21   #69
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
I'm wondering if the 2010 doesn't report that info over OBD II
-J
Present:
2018 Tesla Model 3 DM. 17,000 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 28,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old September 5th, 2012, 05:03   #70
Blue_Hen_TDI
FWIW, I've tried programming x-gauges for all four of the fahrenheit Catalyst Temperature for CANSF vehicles (http://www.scangauge.com/support/xga...ansf-vehicles/).
I was able to get a reading for Bank 1, Sensor 1, which is what I believe most folks are using for monitoring EGT, and I was also able to get a reading for Bank 1, Sensor 2. I wasn't able to get any data for Bank 2, Sensor 1 or Bank 2, Sensor 2.
What I've noticed in monitoring Bank 1, Sensors 1 and 2 for a couple of days is that they roughly follow the same curve, but with sensor 2 about 30 seconds behind sensor 1, so I assume it's a sensor further downstream in the emission system.
Old September 5th, 2012, 08:56   #71
TomB
Have Fun!
Don
I confirmed on the VCDS this morning during a regen that EGT #3 is the DPF temp. It was a steady 582 Degree C.
And yes, I confirmed increasing the engine RPM's during idle DROPS the temp, requiring MORE post injection durations to achieve the 582 Degrees C.
Also, post injection #3 seems to be active all the time. Post injection #1 and #2 seem associated with the Regen cycle. I logged a trip over the mountains this last week and the Post Injection #3 was always active on heavy acceleration or climbing altitude.
Old September 5th, 2012, 15:59   #72
tomo366
TDI Lifer
tomo366's Avatar
So the reason I bought the Scan Gauge is no longer valid.....So if if anyone is interested My Scan Gauge is for sale.....
Old September 5th, 2012, 16:05   #73
Good Ol' Boy
VeeDubTDI's Avatar
That's a bummer!
Old September 5th, 2012, 16:15   #74
compu_85
Gadget Guy
compu_85's Avatar
I bet SpaceMonkeyMafia will buy it from you
Old September 6th, 2012, 12:22   #75
tomo366
TDI Lifer
tomo366's Avatar
I posted it here and it sold in a 10 minutes.......
Scangauge Boost Gauge and General XGauge Coding info seftonm OBD Scanners 131 May 5th, 2015 11:56
fs: NewSouth Performance 0-35psi boost gauge, egt gauge, dual gauge pod ruck Private TDI Items for Sale/Wanted 9 July 11th, 2014 21:35
Scan gauge II OntarioVW_TDI VW MKIV-A4 TDIs (VE and PD) 2 March 26th, 2012 19:20
scan gauge II Help OmegaRenegade Ontario 18 December 20th, 2007 08:27
Scan Gauge II BioThomas VW MKV-A5 Golf/Jettas 53 March 13th, 2007 21:43
Page generated in 0.18835 seconds with 11 queries
[Output: 138.15 Kb. compressed to 115.99 Kb. by saving 22.16 Kb. (16.04%)]
