Old April 30th, 2012, 09:44   #1
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
Lightbulb Passat NMS VCDS Tricks / Upgrades
Starting this thread to keep track of VCDS tips and tricks which apply to the American Passat. A lot will carry over from other models, but this will give one spot to look for Passat owners.
Here's a list of links:
Enable Rain Sensing Wipers. 2012s come with this turned off.
Enable Rain Closing Feature. Shuts all the windows and sunroof when the alarm is set and the windshield gets wet.
Remote Control Windows / Sunroof. As of April 2012 we do not know how to enable remote control of the windows. I was able to get remote opening / closure of the sunroof working by changing the long coding on my Body Control Module.
Enable Voice Commands on the RNS-510 These get turned off by an update, but are easy to re-activate.
Enable the factory perimeter alarm. This is a very basic alarm system. Many cars didn't have this turned on from the factory.
Thanks,
-Jason
Present:
2018 Tesla Model 3 DM. 17,000 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 28,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old April 30th, 2012, 09:46   #2
Good Ol' Boy
VeeDubTDI's Avatar
Rain-closing video: http://www.youtube.com/watch?v=csex2ceKyqE
Old May 1st, 2012, 07:35   #3
wolfsburg_de
Ross-Tech AssociateVendor
Fuel Economy: 33.5 mpg, mostly city
Here are some links to our wiki pages (which are evolving):
http://wiki.ross-tech.com/wiki/index...t_%28NMS/A3%29
http://wiki.ross-tech.com/wiki/index...S/A3%29_Tweaks
support@ross-tech.com
wolfsburg_de is offline   Reply With Quote
Old May 2nd, 2012, 19:40   #4
compu_85
Gadget Guy
compu_85's Avatar
I found you can pick a combination of options in the BCM which puts a menu option in the MFA for the daytime running lights
-J
Present:
Past:
Old May 2nd, 2012, 20:22   #5
compu_85
Gadget Guy
compu_85's Avatar
I'll have to go look at the car again, I want to give the exact bits I checked.
Note that I had to get the latest VCDS from Ross-Tech's website, even though the version on my computer said it was up to date. The version I had didn't have descriptions for the long coding bits.
-J
Present:
Past:
Old May 3rd, 2012, 08:50   #6
Good Ol' Boy
VeeDubTDI's Avatar
This is a factual reference thread, not an argument about history and semantics. All are advised to keep it civil and think before posting.
Old May 3rd, 2012, 09:15   #7
Niner
duplicate account, banned
-J
Cable arrives tomorrow morning... will VCDS 11.11 cover it? I loaded it 4/30/2012? Or are you on a beta tester version?
Niner is offline   Reply With Quote
Old May 3rd, 2012, 09:53   #8
wolfsburg_de
The latest version (and the one that should be used) is Release 11.11.3
http://www.ross-tech.com/vcds/download/current.html
There is currently no beta.
Old May 3rd, 2012, 16:51   #9
compu_85
Gadget Guy
compu_85's Avatar
By enabling Byte 15 bit 7 in the BCM I got this nice menu option in the MFD:
You can also change the DRLs to only come on when the headlight switch is set to auto by checking Byte 26 Bit 3:
-J
Present:
Past:
Old May 3rd, 2012, 19:01   #10
Niner
I thank ye very kindly Jason... Keep in mind Matt has set my DRL's so that they were off all the time, I think he unchecked box 6?
I had to click both box 6 and box 7 to get mine to work, 3 was already clicked. Went into 09 Electronics>07 coding> Long Coding, then had to press the down arrow alot of times to scroll to the right to get to the correct box to check the proper boxes to get a C8 configuration.... With only box 7 checked I kept on getting an 08 configuration.... missed box 6 needing setting also, 3 was already set. Live and learn with hexidecimal, when one is not a digital wizard.
Edit: Something else I found in there is that you can enable your car to beep the horn twice when the alarm gets turned off and you un arm it to open up the door. Didn't test it when I changed it, and had the car unlocked since it was in the garage, but I found it today when I was parked in public and came back to the car, I'd completely forgotten about that change. Two beeps from unlocking was a first on the passat.
Many thanks to the folks at VCDS for finding the goodies in there for us.
Old May 8th, 2012, 08:58   #11
Niner
Credit to Wolfsburg de...
How to adjust your MFI fuel MPG readings if they are optimistic or pessimistic.
Mine has shown itself to be optimistic by 1.8 mpg or 5%. I just used VCDS to go into 17-Instruments->Adaptation->"Display correction of consumption and operating range", and put in a new value of 105%. The controller accepted it but I haven't had a chance to find out if that has the desired effect. I only fill up about once per month so it may be a while.
Old May 10th, 2012, 19:35   #12
mrfly19
Fuel Economy: 42 mix Hwy/city
Smile Tweaks
Thanks for the tip. I did both worked great
Thanks,
-Jason
mrfly19 is offline   Reply With Quote
Old May 12th, 2012, 14:54   #13
Manitoba TDI Passat
Smile Dedicated Area for 2012 Passat Appreciated
Great to have one dedicated area for the new 2012 Passat, it really makes it easy to find the info you need. My Thanks!
Manitoba TDI Passat is offline   Reply With Quote
Old May 12th, 2012, 16:19   #14
compu_85
Gadget Guy
compu_85's Avatar
I found that by changing the cluster's country code to Saudi Arabia the seatbelt chime changes to a much more pleasant one. You can then go through the MFD and change all the units back to what you want. The climatronic displays match the setting in the cluster
Still haven't figured out how to get the single side parking lights working :/
-J
Old May 12th, 2012, 18:57   #15
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Single side parking lights?
Try turning the car off and then turning on the turn signal on the side of the car that you want the SS parking light to light up on.
Works on my 2006 jetta without any VCDS help. Other models may not work this way.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Black Grille on Passat NMS passatti VW Passat Family (NMS and B7) TDIs (2012+) 18 April 8th, 2013 09:09
What is the Passat NMS engine??? TDI2000Zim TDI 101 5 October 12th, 2012 17:55
You know you love your 2012 NMS Passat TDI when... Niner VW Passat Family (NMS and B7) TDIs (2012+) 39 May 29th, 2012 08:35
VCDS tricks? physicshogon OBD Scanners 8 October 20th, 2011 22:56
Page generated in 0.16506 seconds with 12 queries
[Output: 139.20 Kb. compressed to 117.00 Kb. by saving 22.20 Kb. (15.95%)]
