Old September 25th, 2012, 16:03   #16
quinby1
quinby1's Avatar
Fuel Economy: 42 local, 48 hwy
So has anyone found the answer to the original question? "can the '12-13 Passat fuel filter be primed by turning the key three times, or do you need computer access or to hot wire pumps?"
quinby1 is offline   Reply With Quote
Old September 25th, 2012, 16:56   #17
FormerOwner
FormerOwner's Avatar
Fuel Economy: 35 city / 48+ hwy
I will have your answer NEXT WEEK when I return for my 10K mile service.
FormerOwner:
2002 VW TDI Wagon Candy White
1982 Audi 4000S diesel 1.6L
Current Owner: 2010 F-150 XLT SCREW 4x4; 2013 VW Passat TDI SE 6M; 2005 Toyota Camry LE
FormerOwner is offline   Reply With Quote
Old September 25th, 2012, 23:53   #18
no-blue-screen
TDI Nut
TDI(s): TDI
You don't need to prime it folks. When you turn the key you should hear the canister fill.
no-blue-screen is offline   Reply With Quote
Old October 4th, 2012, 09:55   #19
TomB
Fuel Economy: 34 mpg on first tank
Funny on the oil change video he says your-ea instead of you-rea.
The dipstick is not a good indicator of oil level during a drain. After about 1 -2 liters having been removed it will show as empty on the dipstick.
As well you should remove the filter and open the oil cap before you drain. This always frees up additional oil to drain out of the engine.
2007 Jeep Grand Cherokee 3.0L MB Diesel
2012 Passat TDI SEL Premium Opera Red/Titan Black
2015 Audi A3 TDI Prestige S-line Lotus Gray Metallic/Black Leather
TomB is offline   Reply With Quote
Old October 7th, 2012, 18:23   #20
FormerOwner
You are correct, no-blue... they simply remove and install new filter element. They don't dump the diesel out of the housing either. A visual inspection is done... and then the new one is inserted. Turn the key to on for a few moments and then crank the car.
FormerOwner:
Old October 11th, 2012, 17:21   #21
Softrockrenegade
Softrockrenegade's Avatar
This is good news! Sure makes things easier . I just went out to my new Passat and def here something running in the back when cycling the key !
Softrockrenegade is offline   Reply With Quote
Old July 25th, 2013, 01:31   #22
jrm
Fuel Economy: 42/52
Any link to DSG maintenance? I have owned them before and now that im the first owner of this car I want to drastically over maintain the DSG
2015 Passat TDI SEL
2013 Passat TDI SE+NAV 48MPG (totaled)
2012 Ram 2500 Longhorn 15MPG tops
2009 Highlander Hybrid aka the HIHY 25MPG
1996 Dodge mechanical Cummins 12V 2500 4x4
jrm is offline   Reply With Quote
Old August 1st, 2013, 14:34   #23
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
Here is a link I found:
http://www.youtube.com/watch?v=tBYQnjur_wg
Looks like this is on a Golf/Jetta - can't imagine that it's much different on the Passat. Hopefully someone else can confirm. A coworker bought the refill kit and I helped him change his. Pretty easy - just make sure the car is cold first. After a couple of hours, the fluid temp (after changing) was still too high to check level. It warms up pretty quickly so start stone cold if possible.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old August 12th, 2013, 13:46   #24
jrm
Fuel Economy: 42/52
Since every rig I own has at least 200,000 miles on it I need this NMS to be a half million mile car- so I plan to do the top fill method at 20,000 miles just to be 100% sure the fluid is metallic free and assembly RTV free. I have never had to tear down a engine or trans on my rigs in my entire life but have rebuilt family and friends autos several times- rule of thumb is if it isn't broken fix it
I know im comparing apples to pickles here but I dropped the oil on my Honda ATV at just 100 miles (1,000 was recommended) and the filter was completely packed with orange RTV- causing low oil pressure when operated at redline.
I feel that $60 oil change 100% saved the engine.
Take care guys, Joe
2015 Passat TDI SEL
Old September 29th, 2013, 21:21   #25
Good Ol' Boy
VeeDubTDI's Avatar
Looking for RNS 510 navigation firmware and map updates or information? See the following thread...
RNS510 Firmware & Maps Info Thread
Old December 14th, 2013, 16:02   #26
Good Ol' Boy
VeeDubTDI's Avatar
I just added the following information to post #2:
Turbo Failure Discussion:
General Discussion Thread: http://forums.tdiclub.com/showthread.php?t=360617
Failure Reports Thread: http://forums.tdiclub.com/showthread.php?t=375789
Data Collection Thread: http://forums.tdiclub.com/showthread.php?t=381481
Old December 22nd, 2013, 11:31   #27
Good Ol' Boy
VeeDubTDI's Avatar
Added the link to the cabin air filter change How To thread in post #2. Thanks dubStorm!
Old February 28th, 2014, 05:50   #28
vw2011
Default How to prime furl filter canister using VAG-COM
Found video on you tube ,did mine fuel filter at 20000ml
-remove old filter
-emptied filter housing
-install new filter
-add liquid moly diesel purge
-connect vag-com run fp test twice (you can hear pump inside tank)
start a car
http://www.youtube.com/watch?v=c60kY2zqOgI
vw2011 is offline   Reply With Quote
Old March 17th, 2014, 22:34   #29
Good Ol' Boy
VeeDubTDI's Avatar
Updated to add AARodriguez's guide for removing the ECU bracket. http://forums.tdiclub.com/showthread.php?t=410144
Old March 26th, 2014, 09:27   #30
JdC Machine
JdC Machine's Avatar
I'm approaching my first 10k mile service. As such, I've been getting a "Service in X-number of days" message in the MFD for about a couple of weeks now and just within the last few days, the message changed to "Service Now."
My question is, do I wait until the 10k mile mark or go by what the car is telling me? My instinct is to wait until 10k miles.
Hunted and pecked from a Galaxy S4A.
Jim
2013 Passat TDi SEL
Opera Red
Titan Black
JdC Machine is offline   Reply With Quote
tv tuner in a b7 nms mattfrayage VW Passat Family (NMS and B7) TDIs (2012+) 0 February 19th, 2013 14:21
NMS versus B7 jafische VW Passat Family (NMS and B7) TDIs (2012+) 23 December 26th, 2012 11:23
OEM B7 NMS Passat Mud Flaps are here! Fixmy59bug Vendor & GroupBuy items for sale 8 November 28th, 2012 11:40
Chassis Ground points 2013 Passat B7/NMS ? freeman VW Passat Family (NMS and B7) TDIs (2012+) 1 September 18th, 2012 22:38
New cars & emissions musings, moved from NMS/B7 storx TDI (Diesel) Emissions 18 August 28th, 2012 14:07
Page generated in 0.15124 seconds with 11 queries
[Output: 129.22 Kb. compressed to 107.89 Kb. by saving 21.33 Kb. (16.51%)]
