Old September 18th, 2007, 10:33   #1
solarmike
Default 1Z, AAZ Whats the difference?
I have been researching which TD to put into my vanagon. I see engine codes stating 1Z, AAZ and others. Where can I find out which type each is and what the difference is. I looked in the TDI FAQ's and didn't see it there. What can anyone say about the TD vs TDI in the US. Anything is better than my wesser boxer.
solarmike is offline   Reply With Quote
Old September 18th, 2007, 13:35   #2
GoFaster
Moderator at Large
1Z is a TDI direct injection electronically controlled rotary-pump engine, the first version of TDI to be sold in North America (1996 - 1997 Passat TDI and some early 1997 Jetta TDI).
AAZ is an older style mechanical-pump indirect-injection (prechamber) engine. It is a development (longer stroke) of the old 1.6 TD engine. Not TDI. This was sold originally by VW in Canada, 1993 - 1997, but never in USA.
There are tons and tons of other engine codes. The ones most commonly seen in North America for TDI engines, and what they are from, are:
AHU - Jetta TDI (late '97, all '98, A3-body early '99). Rotary pump, wastegate-style turbo.
ALH - all New Beetle through 2003, Golf and A4-body Jetta late '99 through 2003. Rotary pump, VNT turbo.
BEW - all Mk4 P-D TDI 2004 and onward
BRM - Mk5 Jetta P-D TDI through 2006
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old September 18th, 2007, 18:06   #3
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
AAZ has no intercooler, a handle to operate the cold start assist, glow plugs operated by a fixed time initiated by the driver's door opening, a cable operated fuel injector pump and 75 hp.
The 1Z has an intercooler, ECU control of the idle speed, glow plugs initiated by the ignition key and timed and monitored by the ECU, a 'drive-by-wire' electronic accelerator pedal / injector pump control, and 90 hp.
Svante Arrhenius 1896
Old September 21st, 2007, 15:29   #4
solarmike
What years were the kkk turbo used and when did the garrett turbos start being used. Different engine mount kits are better for one and not the other.
Old September 21st, 2007, 18:22   #5
GoFaster
Moderator at Large
If I remember right, the AAZ (indirect-injection) used a KKK turbo but I'm not sure which one. The 1Z uses a Garrett GT15. The AHU uses a KKK KO3-006 which is entirely interchangeable with the GT15.
Brian P.
Old January 12th, 2019, 15:12   #6
Corradoboy18
Which turbo is bigger. The KKK or the GT15?
Sent from my Pixel 3 using Tapatalk
Corradoboy18 is offline   Reply With Quote
Old January 13th, 2019, 14:54   #7
RoseBud68
Wow dug out an 11 year old thread.....
Read this.
http://www.tdiclub.com/TDIFAQ/index.html
1999 MK3 Jetta TDI 1Z.
RoseBud68 is offline   Reply With Quote
Page generated in 0.15442 seconds with 10 queries
[Output: 74.30 Kb. compressed to 63.98 Kb. by saving 10.32 Kb. (13.88%)]
