Old October 18th, 2012, 18:15   #2716
TooSlick
TDI(s): Audi 100S
Viscosity is almost never going to stay exactly the same as fresh oil. Causes of thickening include:
1) evaporation of lighter fractions of the base oil and/or additives
2) oxidation and nitration - chemical reactions with O2 and NO2.
3) buildup of soot and silicon
Nothing to see here, analysis results are fine.
TS
TooSlick is offline   Reply With Quote
Old October 18th, 2012, 18:47   #2717
Ski in NC
Fuel Economy: 48-52 typical
Originally Posted by Bob_Fout View Post
1.5 quarts of make up oil added? 100C visco is 14.2 cSt on the spec sheet.
1.5 total qt burned. Started off full, at about 6000mi added 3/4qt. At change time it was back at add mark. So only added 3/4qt, but it burned twice that. Not going to top up at change time!
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old October 18th, 2012, 19:05   #2718
TooSlick
TDI(s): Audi 100S
Ski,
Are you running the Rotella T6 in the Cummins marine engine? I'd be interested to see how it holds up under continuous heavy load. Most 5w-40's will shear under those conditions....
TS
Old October 18th, 2012, 19:09   #2719
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
OK, if you only added 0.75 quarts of new oil over the OCI, it should reflect that.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old October 18th, 2012, 19:27   #2720
Ski in NC
Originally Posted by TooSlick View Post
Ski,
TS
No, I run regular Rotella T 15-40 dino oil in that engine. On that boat it runs a very light duty cycle, cruising at 1100rpm and about 10% load. Not enough heat anywhere in the engine to justify running synthetic. Occasionally I run at 75% power and 2100rpm to blow things clean. I did an oil sample and it came out ok, but copper was high. I think the low load may get some moisture in oil and it leaches the oil cooler. Otherwise, sample ok at 300hr interval.
If fuel prices were lower, I'd cruise at 1900-2100rpm but that's about 12gph (estimated) and that's 50 bucks an hour. At 1100rpm its 2gph (verified over 8500nm).
I know the low load is not the best for the engine, but the fuel prices dictate duty cycle.
I often take oil samples on other Cummins marine engines, and none of these were using synthetic. Even at high load factors, the Cummins samples show good results unless there is an underlying issue such as sea water driven corrosion. Even dino oil holds up well.
The marine engine crowd has not adopted syn oil, except late model MAN engines, where it required. Cummins, Cat, Yanmar do not require it for warranty, even with high specific output.
Bob Fout: You are being picky. It used 1.5 qt. If I never added oil, it would be 1.5qt low and makeup would be zero!! And I think I was in the beers when I filled out the slip, so there.
Old October 18th, 2012, 19:53   #2721
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
I'm not being picky really. "They"/"We" really don't care how much oil was consumed, only how much "new" oil has been added during the interval, as this will skew the results. Take into account how much new oil has "contaminated" the sample and how long ago it was added.
Old October 18th, 2012, 20:46   #2722
OlyTDI
TDI(s): '04 Golf
Below is a recent UOA.
Details: Mobile 1 TDT, bypass filter, original cam/lifters, almost all highway commute miles, 3 oz. ZDDP added at about 10K into this interval. I burn between 5% and 20% biodiesel with no additives.
No obvious problems I can see in terms of wear. I'm interested in knowing what the boundary is with regard to interval extension and whether TBN is something I need to be getting on future UOAs. Any/all analyses and comments welcome.
Thanks!
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is offline   Reply With Quote
Old October 18th, 2012, 20:52   #2723
Ski in NC
Fair enough. Dilution by new added oil would not change much regarding the numbers in this case.
My thinking with this sample makes me a bit skeptical of those engines that can go a full OCI without top up. Do they consider the oil level drop as I did, are the engines that tight, or a little BS involved??
Old October 18th, 2012, 20:57   #2724
Ski in NC
Oly- That sample looks stellar. Wear metals low, insolubles low, TBN still high, dilution low. You could run that oil longer.... How much longer?? Good question. Others may have an opinion.
Old October 18th, 2012, 21:52   #2725
OlyTDI
TDI(s): '04 Golf
Thanks, Ski -- it's certainly encouraging!
2004 Golf GL PD TDI
Old October 19th, 2012, 08:54   #2726
TooSlick
TDI(s): Audi 100S
Oly,
It's always tough to extrapolate test results based on one data point. However I'd certainly feel comfortable extending this batch of oil out to 20,000 miles based on the overall parameters shown here. As for the TBN limit, if you're using Blackstone labs I'd use a condemnation limit of 25% of the baseline TBN (~ 2.6 for the Mobil 1). If you're testing with other labs using the ASTM "D-4739" protocol (Oil Analyzers Inc., AVLube, etc), I'd use a lower limit of 33% of the baseline TBN.
The TBN may not be the limiting factor in how long you can run the oil. You also have to look at viscosity, soot, silicon, fuel dilution, etc.
FWIW, I don't think doping any oil with supplemental additives is advisable.
TS
Old October 19th, 2012, 09:07   #2727
Scratcher
Scratcher's Avatar
TS
Amen to that!
2011 VW Sportwagen TDI
1984 Ford F250 6.9 IDI (Diesel)
2012 Subaru Outback Premium 6sp MT
Scratcher is offline   Reply With Quote
Old October 19th, 2012, 10:33   #2728
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
All the numbers are affected *some* by new oil. TBN, additive levels, visco etc. 15% volume isn't a lot though, and well within normal usage.
I would say 0.5 quarts is "normal" average oil used for 10K miles for most. If you fill the to max mark (this is not the hash, but the bend) at an oil change, 0.5 quarts puts you at about the middle of the hash at change-out.
Old October 19th, 2012, 17:32   #2729
OlyTDI
TDI(s): '04 Golf
Thanks, TooSlick and Scratcher -- I was sort of under the impression that zinc was a primary limiting factor in longevity of the interval -- perhaps not. I also understand that excess would probably not be good for the CAT but that this was't too excessive.
So do you think that the added ZDDP made no difference? Do you think my analysis would be similar had I not added the ZDDP?
Thanks for the input guys!
2004 Golf GL PD TDI
Old October 19th, 2012, 17:45   #2730
TooSlick
TDI(s): Audi 100S
Oly,
Look at the results of your previous test. You had 1/2 as much ZDDP and the wear profile was essentially the same. You're not going to use up the ZDDP in any oil under normal conditions...
TS
Page generated in 0.19856 seconds with 10 queries
[Output: 132.61 Kb. compressed to 111.49 Kb. by saving 21.12 Kb. (15.93%)]
