Old January 19th, 2019, 01:01   #16
blinkx
Originally Posted by relumalutan View Post
Don't forget the 10 to 12 pin harness:
https://www.aliexpress.com/item/HID-...379810661.html
Thanks again, I got this harness and my friend was able to purchase the housings.
ok dumb question. What about the wire that connects to the bulb to the ballast? is that included or part of the harness?
blinkx is offline   Reply With Quote
Old January 20th, 2019, 10:18   #17
relumalutan
relumalutan's Avatar
It's part of the Headlamp housing. There is the connector to the ballast on the bottom of the headlight (that connector has the wires routed inside of the housing ). Inside the headlamp you will see a designated calble with a connector for the igniter (the igniter will be attached to the D2s bulb). In conclusion, the only harness you need is the 10 to 12 pin one.
relumalutan is offline   Reply With Quote
Old January 20th, 2019, 13:08   #18
blinkx
Great, thanks for the info.
Also, in case the housings the not include an igniter. What are the specifications that I need to search for in case I need to buy an igniter ?
Old January 20th, 2019, 16:04   #19
relumalutan
I gave you their part number in one of my previous postings: 1 307 329 076
Old January 20th, 2019, 16:15   #20
blinkx
got it, thanks!
Old January 29th, 2019, 00:19   #21
garreth5
TDI(s): jetta
Any update on this, OP? Post some pics when you can.
garreth5 is offline   Reply With Quote
WTT: My Depo projector/halo headlights for your OEM black housing halogen headlights tightgtp Private TDI Items for Sale/Wanted 17 September 28th, 2012 06:34
Projector headlights upgrade for jetta MKIV carlos18 Upgrades (non TDI Engine related) 0 May 27th, 2012 21:12
Projector headlights for '09 Jetta? LBJ (Laser Blue Jetta) Upgrades (non TDI Engine related) 6 October 19th, 2009 12:49
installing aftermarket projector headlights-wiring to factory plug hdljet Upgrades (non TDI Engine related) 1 May 4th, 2006 17:00
Page generated in 0.12223 seconds with 13 queries
[Output: 75.47 Kb. compressed to 66.25 Kb. by saving 9.21 Kb. (12.21%)]
