Old January 18th, 2019, 12:08   #1
Kyleig
TDI(s): 2001 Jetta
Default 02 Jetta white smoke/ miss
Need some insight...long story short, turbo shaft sheared,(but no fins cam off) motor tried to run away but I caught it before it even got passed 3k. Went with a Xman vnt 20. Iím on Malone stage 4, .216, an everything to support it. Ran great before the turbo went. Now it starts right up idles good but once any throttle is opened it gets rough and Iím getting white smoke thatís very strong of diesel. Timing is good, on the green line like it was before, IQ is 3.8, no codes. Hasnít gone down the road yet. If I rev it and let off it runs rough like itís missing for a few seconds then smooths out. It never hydro locked and it didnít seem like a pile of oil went into the motor. I drained about a pint or a little more out of the intercooler. Had the injectors checked out an their all good. Attempting a compression test but none of my adapters fit the injector hole or the glow plug. The numbers on the mass air and map sensors donít seem right, according to Ross tech they are not.
To me it seems like itís just dumping fuel into it. Itís always possible it bent a rod but I doubt it.
Whatís everyone using to check compression?
Mass air specifies is 465 mg/str at idle
Mass air actual is 515
Map is showing 819 at idle. And goes down when I rev it.
Kyleig is offline   Reply With Quote
06 Help Needed Miss with White Smoke ryan903w TDI 101 4 January 20th, 2014 05:08
Intermitant miss ip clicking white smoke whytry97 TDI 101 24 October 25th, 2010 23:26
Intermitant miss ip clicking white smoke whytry97 TDI 101 0 October 11th, 2010 02:01
White Acrid Smoke with Stumble/Miss at Cold Start sassy VW MKIV-A4 TDIs (VE and PD) 13 January 7th, 2005 18:52
Page generated in 0.13099 seconds with 13 queries
[Output: 46.69 Kb. compressed to 44.03 Kb. by saving 2.66 Kb. (5.69%)]
