Old January 17th, 2019, 08:33   #1
Iwcham
Default Quick heatsoak question
Is there any difference in the same engine, say ASZ, dealing with heat at stock hp and then remapped to 40hp more, at a constant freeway speed of,say, 170km/h, on the same oem smic?
Sent from my SM-J510FN using Tapatalk
Iwcham is offline   Reply With Quote
Old January 17th, 2019, 09:15   #2
scooperhsd
I don't have any issues on my ALH New Beetle that is outputing 170% of stock torque and Horsepower......
2000 Red NB TDI, 370,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old January 17th, 2019, 09:31   #3
Iwcham
On the stock smic? That's good to hear Then from 130hp to 170hp on my ASZ Fabia, there is no need for an expensive fmic
Old January 17th, 2019, 09:34   #4
AndyBees
AndyBees's Avatar
The ALH in my Vanagon hasn't shown any semblance of increased heat with Stage 1 Tune (about a 15-20% increase in HP) while pulling a camper.
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
AndyBees is online now   Reply With Quote
Old January 17th, 2019, 10:02   #5
Iwcham
Ok guys. Thats good to hear. I made a similar post in another forum section because that part of my questions was kind of overlooked but just got a similar answer, that heat soak at high constant speed shouldn't be the issue, because the turbo isn't making so much boost... Since I don't abuse the car on tracks, don't drive too agresively on winding country roads either, or go through the gears like a maniac, I may just remap my ASZ. I will give it new ARL 1749VB turbo and headbolts and call it a day....
Old January 17th, 2019, 10:58   #6
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
I've read the stock IC is good for quite a bit of power, not sure how much. There's bound to be a tad more heat, since everything works a bit harder, but it would hardly be noticeable.
Old January 17th, 2019, 16:44   #7
ToxicDoc
TDI(s): 2001 Jetta
From a physics standpoint, if you are travelling with the same load, the heat should be the same - e.g. if you need 60 hp to travel at 170 kph, even if the engine can now make 200 hp, it still only uses 60 hp under those circumstance. The heat issue becomes a factor under acceleration
ToxicDoc is online now   Reply With Quote
Old January 17th, 2019, 17:09   #8
Rrusse11
"heat soak at high constant speed shouldn't be the issue, because the turbo isn't making so much boost"
Lol, now do you believe me?
RC Stage 4: 11mm pump, 17/22, .230 nozzles, 3barMAP,EGR Delete, PD150Intake,SMIC,2.5" Exhaust: Koni Sp Reds, Wagon Springs, ~1"/2"lift:VR6 fr swaybar, Top strut & rear tie bar: 215/55ZR16 GMax AS05's, 10mm/20mm spacers, 35# @: skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: : VR6 fr, TT rr Brks
Rrusse11 is offline   Reply With Quote
Old January 17th, 2019, 22:19   #9
Iwcham
Yep
quick question JayT TDI 101 2 December 28th, 2011 18:05
Quick question, real quick. Lukehmk4 TDI 101 5 November 5th, 2008 15:52
Quick question WrEkkED TDI Power Enhancements 8 January 21st, 2008 15:15
Very Quick Question... tmoya4646 TDI 101 21 October 20th, 2007 21:10
Quick coolant fill up question! Quick! Tybrad TDI 101 10 July 26th, 2007 11:13
Page generated in 0.14808 seconds with 13 queries
[Output: 89.10 Kb. compressed to 76.25 Kb. by saving 12.86 Kb. (14.43%)]
