Old November 14th, 2018, 11:21   #1141
rustycat
Originally Posted by dna007 View Post
Finally after 3 years "Here Maps" former "Navteq" decided to release new maps on October 21st 2018
Continental Automotive GmbH
I IC RD CC NAV DB PROD
Content
Volume: CD_8534
Date: 16.5.2018
db: NA(2018Q1)
Area: North America
Subarea: ALL
Supplier: Navteq
Version: 505.19.810.2.84
Customer Version: V12
Customer: 1627386654
Customer Info: VW
Features: ZIP3kb - feaV10(VW) - pti(VW)
TPD: 2018020002
SVD: EDB_20180214
TMC: 20180112
Phoneme: Navteq
DBAL: VW-V6.36_V7.13_V8.22_V10.13_basename_poi_on_route
SIRIUS:13.05.2011
-Cheers,
Peter
ExtremeNetwork
Thanks for the heads up. I ordered the update an hour ago for my 2015. I know the nav on the rns 510 isn't loved by many, but I find it easy to use, especially when my wife is driving by herself and doesn't want to use waze.
rustycat is offline   Reply With Quote
Old November 14th, 2018, 12:12   #1142
CrustyOreo
TDI(s): 3x Golfs
Fuel Economy: GPM
Mailman was kind today. V12m DVD came today. Updating one of my units rn
2011 Golf 2 Door 6MT: Daily
Past: 99.5 Golf 2 Door, C4 Corvette, OBS 7.3 PSD, more and more junk.
CrustyOreo is offline   Reply With Quote
Old November 14th, 2018, 13:01   #1143
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
When I bought my 2015 Passat I also updated the firmware, map and a program which lets you use the DVD player for movies while underway. Cost in 2016 was under $ 50.00 shipped to me.
I for one think the Navi in my Passat sucks big time. It has asked me several times to enter which country I am in while sitting at home in my driveway and never gone more than 50 miles from home. To enter and save waypoints is a royal PIA.
The VW Navi is Garmin based, but nowhere near as easy to manipulate.But it makes a great back-up screen!
As an aside, I just bought another Garmin GPS which has far more features than the RNS-510. The Garmin gives me three new map updates a year FREE and the whole unit is less than an old VW map update. The current Garmin map is 2019.30.
I'll be damned to pay VW or their agent over $ 100.00 for a lousy DVD which costs them $ 0.15 or less to duplicate. A charge of $10.00 to maybe even $ 20.00 is a reasonable profit but not a 1,000 % profit, that is gouging!
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Old November 14th, 2018, 16:52   #1144
CrustyOreo
TDI(s): 3x Golfs
Fuel Economy: GPM
Probably a dumb question but can the firmware be updated via a burned CD with the proper files or does it have to be a DVD?
Old November 15th, 2018, 14:59   #1145
BarryT82
You can use a burned disc. I have the map dvd for sale in the classified section.
BarryT82 is offline   Reply With Quote
Old November 22nd, 2018, 19:28   #1146
gflynn
TDI(s): 2012 Passat
Default Navigation Voice
Hello
New to this thread
Have a 2012 Passat TDI and trying to activate the voice command through VCDS
Have followed instructions as per previous posts and still does not work.
Suggestions on what I maybe missing.
Info from unit.
HW-65
SW 3696
Map 7565
Any help is appreciated.
Regards, Gerard
gflynn is offline   Reply With Quote
Old December 2nd, 2018, 09:23   #1147
FedAgent1896
FedAgent1896's Avatar
Good morning forum users...
Was curious if one of you could tell me if there is another firmware version for my car.I currently have the following:
K-Unit RNS510
SW Version - 4369
Map Version - 7963
I have V12 map on my desk, but don't know if I should update firmware first (if there is an update) then update the map. Also, the map update comes with zero instructions. I assume you put the disk in the cd slot and pray???
I started reading this thread from the beginning and y'all are alot more technically savvy with this than I am. But I also did not real all 70+ pages of threads. Any help or info would be appreciated.
Si Vis Pacem, Para Bellum
FedAgent1896 is offline   Reply With Quote
Old December 25th, 2018, 20:04   #1148
jrm
Fuel Economy: 42/52
just picked up a 2015 SEL, now I totally understand what people have been talking about- wow the 510 is so slow, backup cam rarely works in time, normally it comes on about 100 feet away from the spot I backed up at. as for video in motion, I downloaded the video in motion "update" and it ran the berto 89 recode and updated correctly, rebooted correctly but the video in motion still doesn't work. probably due to it being a late model 510
2015 Passat TDI SEL
2013 Passat TDI SE+NAV 48MPG (totaled)
2012 Ram 2500 Longhorn 15MPG tops
2009 Highlander Hybrid aka the HIHY 25MPG
1996 Dodge mechanical Cummins 12V 2500 4x4
jrm is offline   Reply With Quote
Old December 28th, 2018, 02:23   #1149
BarryT82
If you install the firmware update it has VIM included.
Old December 28th, 2018, 09:47   #1150
rustycat
Hopefully, someone can provide info/suggestions on what to do. I ordered and tried to install the new Oct. issue Nav/Map update version 8534. The disc was left in the head unit for a couple of weeks and periodically I could hear it spinning but it never downloaded and update the existing data. What to do? The RNS510 functions fine otherwise.
Old December 31st, 2018, 04:36   #1151
BarryT82
When the dvd is in the drive press eject. It’ll show the progress. Did you select “save” when prompted?
Old January 2nd, 2019, 22:50   #1152
rustycat
Well, no message at all when I press eject-- the DVD simply ejects.
Old January 3rd, 2019, 04:33   #1153
BarryT82
Then it’s probably loaded. If you’ve updated the firmware you’ll have the secret menu enabled. Press and hold setup, select version info, and check the map numbers.
Old January 3rd, 2019, 15:00   #1154
rustycat
Thanks for the input.
RNS-510 Latest Firmware, 5M Maps SVTWEB Private TDI Items for Sale/Wanted 4 November 1st, 2012 06:53
Rns510 & 9w7 myriad VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 November 19th, 2010 11:19
Hey locals... pump rebuild & info thread michael. West Coast Canada/USA 11 August 12th, 2009 12:02
2 & 3 bar maps Ynot TDI Power Enhancements 8 June 25th, 2005 07:56
Page generated in 0.17424 seconds with 13 queries
[Output: 122.56 Kb. compressed to 103.19 Kb. by saving 19.37 Kb. (15.80%)]
