06 jetta tdi head removal bolt procedure.bentley only has the on Procedure torque to 44 lbs and 1/2 turn in a movement. If removal is same do you start from outside or from the center? I'm backing off 1/4 ccw turn in x patten and repeat this as not to warp head. Thanks for your input. Jim
