Official Ontario stuff for sale thread
TurboABA
Kitchener, ON
RIP-2010 Jetta 6spd 2014 Touareg Execline
My MK5 was written off, so I will be posting parts as I come across them.....
Will have full BNIB JOM SS Coilovers once I dig them out, 19" AMG replica rims, various suspension parts, and whatever else I find.
Here's a few parts that I had easy access to.
Please PM about anything you're interested in as I don't want to pollute this thread with exchanges, prices, negotiations, etc.
New profile blades
2 full sets
OEM rubber trunk liner
OEM rubber winter mats with logo
Full OEM rubber set (above two combined)
SOLD - 17mm bolt covers, removal tool, and security lock socket
Custom made SS304-20ga Mirror Polish Scan Guage panel - fits over the ashtray but does not block the ASR\EPS buttons between it and the shifter.
Can find other pics showing it installed if required. Would probably sell without the SGII since you can find the SGII cheaper to buy then I'd be willing to let it go for.
SOLD OEM 16s with winters - two tires are near mint, two are destroyed on the outsides
No curb rash or anything. Excuse the crude thread depth "measurement".
Rear Upper Shock Mounts
Rear control arm inner bushings
Front Strut Bearings
Oil Filter
Updated.
phantom1260
Brampton, Ontario
1997 Jetta GL IDI, 2010 Jetta TDI (Sold)
Parting out two 2010 Jetta TDI. Both are black. One has leather seats and the other is cloth.
I also have a Diesel Geek Skid Plate
I was doing a DSG swap but am just parting both the cars out now.
So I already have the following removed
CV shafts / Axles
Starter
Intake Box
Two DSG Transmissions - 1 needs a mechatronic. The other one I cracked the housing when installing but have gotten it welded.
1 of them has newer rear calipers
Brand New LUK DMF - I bought it to swap while I was doing the DSG but never installed it.
Let me know if you are looking for something specific.
I was able to get the emissions recall done on the donor car before I removed the transmissions it all those emissions parts are brand new from the dealer. DPF, Exhaust Valve etc
Still have the Diesel Geek Panzer Skid Plate if anyone is interested.
phantom1260
Brampton, Ontario
I got a PM from someone locally interested. My preference would be to sell locally. If that does not go through I'll figure out how much shipping will be.
phantom1260
Brampton, Ontario
Adding some pictures if anyone is interested. I have all the hardware as well except for the riv nuts and the threaded rod both of which can be sourced at home depot at minimal cost.
igiveup
Mississauga, Ontario
2005 Passat, 2009 Jetta
FS - CBEA ECU
ECU from a 2009 Jetta, did not have the emissions fix done on it. Not exactly sure what that changes in the coding. Can include complete wiring harness.
$100obo
Tartrus
Canada
Mk4 BEW Jetta
I have 2 driver's side brake hoses for a mk4 jetta. Moving out of province so if you want em and are willing to come to the KW area I will give them to you for free
bigivn
ON
Jetta
I am the original registered owner of this USB based HEX+CAN interface cable. Unit is in perfect working condition, actual unit shown. Now is the time to ask any questions. Asking $100 including regular post in Canada only. Payment by EMT before I ship. Cheers
Johhny04
Markham, Ontario
2003 Jetta TDi
I'm considering parting out my 02 Jetta. Drivers side front wheel bearing and CV axle failed. While not hard or expensive to replace, I've spent too much money on this car and have had enough. It'll likely need a couple of other bits too, although I have quite an extensive list of new parts on it in the last 2 years. Engine has 418k and a new mahle turbo installed last year, ac blows cold. Car can be heard running before removing engine. Body is ok, underbody is clean, but some body panels are starting to rust given the age. In its current condition it's not driveable. I have the whole knuckle apart and the axle is off the car. I could put the knuckle back on to roll the car, but as mentioned, not driveable and needs a tow. In its current state I'm not sure what it's even worth, hence considering a part out. If anyone is interested in it complete, or wants parts, let me know so I can decide which route to go, and based on that I'll see if it's worth giving it another chance or letting it go, part out or complete
PM is best
Trying to send a PM but it says your profile is private.
P2B
Toronto & Muskoka, Canada
2002 Jetta, 2003 Jetta, 2003 Jetta Wagon
PM is best
It's worth more if it's driveable. I have a used knuckle and axle you can have cheap.
dataiv
Ottawa, ON
2015 Golf Wagon TDI 6MT
Hi all, just posted in the TDI Items for Sale category before I checked for a for sale thread in the Ontario forum... selling EA288 CRUA timing belt tool kit from IDparts as well as the engine support we built for the job. $150 CAD for both, available in the GTA (Burlington). The post is here:
Thanks!
timk519
Kitchener Ontario
Last: 2012 TDI JSW
Set of 4 steel rims off a 99.5 TDI Jetta with old winter tires on them.
They were in storage when I traded the car in and have been hiding under my workbench ever since.
Located in Country Hills Kitchener - $50.
vito3223
I have the following parts for sale, posted and Kijiji and prices are negotiable:
Jetta 2011+ OEM summer floor mats: https://www.kijiji.ca/v-view-details.html?adId=1615248196
Jetta 2011+ OEM cargo liner with net and blocks: https://www.kijiji.ca/v-view-details.html?adId=1615249371
Jetta 2011+ OEM KESSY door handles left and right with harness: https://www.kijiji.ca/v-view-details.html?adId=1618951674
VW OEM Bluetooth module with Wifi: https://www.kijiji.ca/v-view-details.html?adId=1618953950
Audi/VW OEM exhaust tips: https://www.kijiji.ca/v-view-details.html?adId=1618950542
VW PLA 2.0 parking assist kit: https://www.kijiji.ca/v-view-details.html?adId=1618951331
VW OEM Highline reverse camera kit: https://www.kijiji.ca/v-view-details.html?adId=1618952301
VW OEM Rear view mirror with highbeam assist and dimming: https://www.kijiji.ca/v-view-details.html?adId=1618952851
VW Dynamic Chassis Control (DCC) Kit with sensors: https://www.kijiji.ca/v-view-details.html?adId=1618953363
VW OEM Lane assist with camera, harness and trim: https://www.kijiji.ca/v-view-details.html?adId=1618955370
VW OEM box full of harnesses: https://www.kijiji.ca/v-view-details.html?adId=1618954222
VW OEM Trunk easy open kit: https://www.kijiji.ca/v-view-details.html?adId=1618957619
Located in North York.
cdi320
Ontario, Canada
Cdi
I still have a decent chunk of parts left over from my 02 partout/parts collected over the years, I have an updated list with new pictures on kijiji
edit: new listing up in another post
Windex
Cambridge
05 B5V 01E FRF
Someone "worse" than me at hoarding parts - I salute you sir.
cdi320
Ontario, Canada
Cdi
I was shocked at how quickly the big stuff (engine, turbo, etc) sold from my 02 partout, I didn't realize there's still such a following for old mk4s, especially tdi's, so all that considered, I just can't get myself to throw anything out... and who knows, maybe one day i'll own another mk4, as a hobby car, I guess you never know when old parts might come in handy
P2B
We have 4 ALH TDIs in the family, all DDs with just shy of 2 million kms in total.
They are dead reliable, and dirt cheap to operate if you turn your own wrenches. We have no plans to retire any of them anytime soon.
Windex
Cambridge
05 B5V 01E FRF
Freshly rebuilt 11mm fuel injection pump at performance diesel for 5 speed TDI. Never installed, just as I picked it up at the shop. PM if interested
Giles does good work, so you know the pump will be in good shape. He's not cheap though... :)
