Old September 8th, 2017, 14:04   #31
Jetmugg
TDI(s): None
Great Project! I'm very interested, especially in the trans adapter & 6 speed combination. I'm just getting started on a TDI swap into a completely different vehicle, and considering all options for transmissions.
Thanks,
Steve
Jetmugg is offline   Reply With Quote
Old October 10th, 2017, 20:04   #32
evguy1
Finally got this on the road and its surprisingly quick.
I think the 50lb flywheel is a big help with standing starts as we used to stall the original 3.8 gas all the time but not stalled the TDI once.
No real problems with the swap until I tried to put fuel into it at a gas station.
Took 71 cents and the fill pipe would not take anymore so on the weekend I will have to replace the 3/4" existing fill pipe with some 1 1/2".
Still have some wiring to finish including the tach but otherwise its done.
Had to give it to my daughter to get to school this week so we will see how it does in the real world.
Still needs a front bumper and cooler side rails/steps.
evguy1 is offline   Reply With Quote
Old October 10th, 2017, 20:34   #33
Nevada_TDI
Dang, that is one cool beast; I wish I had one. Or two.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, Stage 4 Custom TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Old October 11th, 2017, 02:13   #34
jimbote
jimbote's Avatar
really clean looking engine bay with a nice plumbing layout....where are you venting the crankcase pressure ? ... i just see an open VC nipple
jimbote is offline   Reply With Quote
Old October 11th, 2017, 10:31   #35
evguy1
You just cant hide anything from Jimbote!
Yes one of the remaining little things to finish up.
Have not figured out a nice clean way to get a hose from the vent to the airbox.
Old October 11th, 2017, 10:39   #36
Exenos
TDI(s): 02 Golf
Maybe use a small cone filter from a small carb instead of going to the intake? Or maybe too much oil would be pushed out the vent?
Exenos is offline   Reply With Quote
Old October 11th, 2017, 11:11   #37
jimbote
jimbote's Avatar
what about using a BHW valve cover ? it would point the pvc outlet toward the TIP in your application... or a BRM VC ... pvc outlet is right rear and may it be easier to tuck the hose around to your inlet.... it also has the oil fill on the timing belt end so service may be a bit easier... there is a vacuum nipple though, not really sure what that operates in the VC itself
Old October 11th, 2017, 11:47   #38
xerootg
Provent?
xerootg is offline   Reply With Quote
Old October 11th, 2017, 18:35   #39
Motohead1
I found hooking my PCV straight to the air box (unfiltered side) was sucking in a ton of oil vapor and my compression is good so no blowby. I will put a catch can in between to swirl it.
Yea the heavy flywheel is a must. What you have built here is almost exactly what I want to build for the wifes next ride.
Dodge Dakota QC Tdi
Motohead1 is offline   Reply With Quote
Old October 12th, 2017, 09:29   #40
evguy1
The BHW valve cover looks interesting although finding one around here will be a challenge.
Old October 12th, 2017, 20:56   #41
xjjeeper
xjjeeper's Avatar
Randy there is a bhw at pickapart in Chilliwack currently. I can go Sunday and check it out for you if you like
1999.5 alh soon to be installed in a 1999 jeep xj
xjjeeper is offline   Reply With Quote
Old October 12th, 2017, 22:01   #42
vanbcguy
vanbcguy's Avatar
Is there much 90s stuff in the yard there? Always looking for B3 bits and pieces locally...
Sent from my LG-H873 using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old October 13th, 2017, 17:32   #43
evguy1
Would they sell the valve cover off a good engine? Looks like the car is in nice shape?
If you don't mind I think it would be the way to go.
Not a big deal if you cant make it though.
Old November 26th, 2017, 19:54   #44
evguy1
The Jeep has been running great and lots of power to pull the JKU around even on 33" tires.
Finally did a mileage check and the last tank was 31 mpg (imperial) which I think is much better than the V6 that was in the JK.
The thing we notice the most is the added bottom end torque.
The 3.8 V6 was gutless at the bottom end and we were always stalling it.
Old November 27th, 2017, 03:59   #45
bwk9087
TDI(s): 2003 1.9 ALH
That is awesome, so good to hear!
bwk9087 is offline   Reply With Quote
2008 Jeep Cherokee Diesel $5K GD Ontario 8 September 15th, 2014 19:12
2008 Jeep Cherokee Diesel $6,800 GD Ontario 19 January 29th, 2014 07:55
2008 Jeep Laredo 4x4- trade for a TDI! TDI_01 TDI Cars for Sale/Wanted 7 October 27th, 2010 14:42
What are your thoughts on the 2008 Jeep? keypecker Non VW Group Diesels 11 June 16th, 2009 05:44
2008 Jeep Grand Cherokee CDI Jeffreyspahn General Automotive 9 November 4th, 2008 12:41
Page generated in 0.19150 seconds with 13 queries
[Output: 130.13 Kb. compressed to 108.82 Kb. by saving 21.31 Kb. (16.38%)]
