Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old September 1st, 2017, 11:08   #91
Lightflyer1
Lightflyer1's Avatar
Try it and report back. As you found most find Ross-Tech to be the tool to use. I get a "404: Oops, this page couldn’t be found." for that link.
2015 Beetle TDI.
Old September 1st, 2017, 11:12   #92
JSWTDI09
JSWTDI09's Avatar
Originally Posted by RunTheRace View Post
All I'm seeing is references to Ross-Tech. Does anyone have knowledge or experience with www.totalcardiagnostics.com/vagcom‎ --- this is a $100 unit. Also, will these work with my Apple MacBook Pro?
I've got an electrical issue that needs to be narrowed down.
1) The link you posted gives a 404 (Page not found) error.
2) Any "vagcom" that is not from Ross-Tech is an illegal clone or hack of a Ross-Tech's product. These are usually older versions and they are NOT upgradable. Good luck if you support thieves - there will be no support.
3) VCDS (the program) is a Windows program. It can run on a MacBook Pro *IF* you are running Windows as a VM or in a dual boot setup. It will NOT run under Apple's operating system.
4) A HEX-NET wireless interface with VCDS Mobile will run on a MAC or an iPhone or any other device with WiFi and a web browser.
Have Fun!
Don
2009 Jetta SportWagen TDI (gone but not forgotten)
2018 VW Tiguan SE (I wish it was a TDI)
JSWTDI09 is online now   Reply With Quote
Old September 1st, 2017, 13:11   #93
tadawson
FYI, works great in a Linux machine in a VM as well . . .
tadawson is offline   Reply With Quote
Old September 2nd, 2017, 08:26   #94
St.Hubbins
St.Hubbins's Avatar
Have Fun!
Don
so i'm just jumping into this (finally). i don't have Windows - got a MacBook Pro and a couple gens of iPhones... is the VCDS Mobile the way to go? i really just want to tweak some settings - steering assist, window/fob trick, etc.
thanks, Don
'10 Golf TDI, DSG, 4 doors, United Grey
'01 Passat Wagon V6, dark Blueish Grey? 120k
St.Hubbins is offline   Reply With Quote
Old September 2nd, 2017, 08:49   #95
gassprint1
TDI(s): 2006 jetta
as long as you get the hex-net, you can use any tablet, os system. goto ross-tech.com find the hex net and what the videos. they have many of them on youtube also.
gassprint1 is offline   Reply With Quote
Old September 2nd, 2017, 11:31   #96
St.Hubbins
St.Hubbins's Avatar
cool - not sure i'm ready to spend 500 clams... maybe find a used one, or find a clubber to help.
Old September 2nd, 2017, 11:52   #97
gassprint1
TDI(s): 2006 jetta
don't know where you are getting 500 from, but they are only 199
Old September 2nd, 2017, 13:19   #98
JSWTDI09
JSWTDI09's Avatar
VCDS Mobile in a HEX-NET would work with your Apple products. However, you probably could buy a used wired interface and a cheap used Windows netbook or tablet for less money. (see below)
A HEX-NET wireless interface starts at $449 for a 10 VIN model and $599 for unlimited. For $199 you are thinking about the HEX-V2 (VIN limited) which uses a USB connection and it does require a Windows computer.
Have Fun!
Don
Old September 2nd, 2017, 15:11   #99
gassprint1
TDI(s): 2006 jetta
your right, thought it said same as v2 when i ordered the v2 tuesday
Old September 27th, 2017, 16:40   #100
RunTheRace
RunTheRace's Avatar
Fuel Economy: 39-41 mpg
I'm cheap. How about the wireless plugs that use either wifi or bluetooth which trasnmit to your phone, and use OBD Car Doctor App, etc.???
RunTheRace is offline   Reply With Quote
Old September 27th, 2017, 16:52   #101
gassprint1
TDI(s): 2006 jetta
the hex net is like expensive. cheap would be the hex v2 for $200 for use on 3 cars.
Old September 28th, 2017, 08:27   #102
Nevada_TDI
I own the old, non-locked version of VCDS, but there are times I just want to know some of the easy stuff and I do not like to drive with my laptop. I have an ELM- Bluetooth adapter and Torque Pro for my Android phone and have no trouble reading and or clearing DTC's. I would of never part with my VCDS as there is no way to check my IQ or timing using my phone.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is online now   Reply With Quote
Old September 28th, 2017, 11:10   #103
gassprint1
TDI(s): 2006 jetta
i'm not into it that deep for checking the timing of the pump an such just yet. i have an 06 tdi which read much different than the older stuff. i'm not sure what is different from the old program and the new program either. i have the recent ross tech software version also being i just got it a couple weeks ago. if you check the wiki page on ross tech, there is alot of good info on doing that type of stuff or join a facebook group and ask questions there. sorry i can't be alot more helpful on that part of it. many of the guys have the alh engines an such with mods on my fb group VW TDI Owners might give that a try.
Old December 3rd, 2017, 04:48   #104
Pat Dolan
Fuel Economy: 800km/1100km/tank
OK, here goes: I can use a computer, but I am a very long way away from being a computer geek. I have had Vagcom for years to access wife's '03 Jetta TDI, but one kid bought an '09 B6 variant gasser and the other a '16 B7 TDI so I bought a VCDS license and adapters. HOWEVER: I have a Panasonic Toughbook running Window XP Pro that has my yank tank software on it - and that stuff will NOT run on anything but XP. Before I got to use VCDS, the old toughbook turned out to be not so tough, and I have not had time to do anything about it.
The gasser started throwing codes last week while we were overseas, so kid went to dealer and got a snowjob she could easily recognize as total BS, so I need to get my hardware and software issues resolved.
Because of the old (and new) yank stuff, I sort of need to stick with another XP machine, but my question for the weekend is if I am giving up anything from a performace or functionality standpoint to use an XP machine with VCDS?
side note: local software guru claims he can re-port my other software to run on Windows 7, but not 10.
A4=2003 TDI Variant, A3=Golf CL, A2=2x1.6 Jetta TDs, Golf Syncro Country, A1=Scirocco Mk1 & 16v, Audi 5000TD, Porsche 924/M471 and a bunch of diesel trucks.
Pat Dolan is offline   Reply With Quote
Old December 3rd, 2017, 09:35   #105
JSWTDI09
JSWTDI09's Avatar
VCDS will work perfectly with XP. VCDS does not require a lot of CPU horsepower. Any computer capable of running Windows XP will run VCDS just fine - even a single core Intel Atom netbook (cheap) will work fine. As far as VCDS is concerned, you will "give up" nothing.
Have Fun!
Don
Which VCDS Trimmy OBD Scanners 4 February 27th, 2013 22:22
MK5/MK6 VCDS lite vs VCDS Full?? storx TDI Power Enhancements 3 July 30th, 2012 11:15
VCDS or Not to VCDS, THAT IS THE QUESTION BRADFORDKO TDI 101 6 July 15th, 2011 21:21
used VCDS? ajbowman OBD Scanners 3 September 15th, 2010 18:06
Did I do this with the VCDS? Turbine Suburban VW MKV-A5 Golf/Jettas 1 August 9th, 2009 10:52
Page generated in 0.17925 seconds with 13 queries
[Output: 129.29 Kb. compressed to 108.16 Kb. by saving 21.13 Kb. (16.34%)]
