Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old July 11th, 2017, 23:24   #1
nztdi1
TDI(s): golf mk4
Default Filings in oil r5 tdi
Hello
Have bought a cheap 2003 r5 tdi which was unloaded due to metal shavings in the filter. Price paid will allow for a profit wrecking for parts if necessary but would be nice to keep it alive. Has done over 300000 km's but very tidy. vcds scan shows no codes. I have done plenty of engine conversions, timing belts etc but my experience actually inside engines is limited to a pd130 headgasket replacement. Engine still starts/runs as normal with no funny noises. replacement r5 or paying for a rebuild is out of the question ($$$) what would be the most likely culprit for the metal filings and how involved would a diy repair likely be? I am confident with the engine removal if necessary. Option b is to drive it until it dies then look at swapping a more available engine in(highly tuned 2.0?) although i understand the bellhousing pattern is different and would involve a new gbox + fab work.
Any advice would be greatly appreciated!
nztdi1 is offline   Reply With Quote
Old July 12th, 2017, 12:28   #2
speed185187
speed185187's Avatar
First step is to figure out what kind of metal it is. That will point you in the correct direction to properly identify the failure.
03 Jetta GL TDI reflex silver (daily driver)
16 Silverado 3500 CCLB dually LML
14 BMW K1600GTL-E
speed185187 is offline   Reply With Quote
Old July 15th, 2017, 19:13   #3
Fourdiesel
Fuel Economy: ~53 mpg on Golf (sold)
Not sure which used oil analysis resources are available in NZ but here in the US Blackstone can tell pretty accurately what the source of metal in the oil is. If it is indeed filings that appear in the filter (as opposed to very fine particles suspended in the used oil) then severely worn parts such as camshaft(s)/followers - the easiest to access, timing gear bits - harder to get at, or bits of main, rod of other bearings - hardest to get at; should be examined.
2004 Touareg V10 TDI Colorado Red
Blk 2000 Golf 5spd 2-dr (now grandsons)
Sand Biege 2008 Mercedes GL320 CDI (wife's)
'83 Mitsubishi 4X4 PU(2.3L turbodiesel)
'85 U1700 UNIMOG ["I DO understand - its a UNIMOG thing"]
Fourdiesel is offline   Reply With Quote
Old August 13th, 2017, 03:40   #4
FinnTouareg
As just blind shooting; one of the metal source options can in my opinion be a worn out water pump which locates at the rear of engine, inside the motor. It may also cause an internal coolant leak which may dilute the engine oil and cause exceptional metal wearing in what so ever bearing surface.
FinnTouareg is offline   Reply With Quote
Old August 13th, 2017, 03:59   #5
nztdi1
TDI(s): golf mk4
Thanks Finn
Will keep that in mind, oil doesn't appear diluted. have replaced the camshaft but does appear to still be generating filings unless they were hiding somewhere other than the sump which i cleaned out. Vehicle still runs perfectly fine i had decided to drive it until it dies if it turned out to be the cylinder lining as i don't have much money in the vehicle and a new motor/rebuild is $$$. filings do appear to be magnetic would anyone know if the plasma coating would have that affect on aluminium?
Old August 14th, 2017, 18:49   #6
Fourdiesel
The plasma coating will NOT make the aluminum magnetic. Only iron and nickel can be made magnetic.
Old August 15th, 2017, 05:32   #7
nztdi1
TDI(s): golf mk4
Thanks Fourdiesel, so in that case would you think i could safely say it's not the cylinder lining?
Old August 15th, 2017, 18:57   #8
Fourdiesel
I am quite sure that those particles are NOT from the cylinders. That does not guarantee the cylinder lining is OK, just that that material didn't come from the liner.
2011 Jetta 6MT tranmission oil leak with metal filings DieselCk VW MKVI-A6 Jetta Sedan (~ 2011+) 3 June 27th, 2017 12:54
Audi 200 R5 TDI VMP TDI Power Enhancements 44 September 6th, 2013 11:45
TDI R5 in mk1/mk2 is it possible? jabcok20 TDI Power Enhancements 1 June 17th, 2013 06:11
High vibration from R5 TDI motor AntonvBosch VW Touareg TDIs 6 May 17th, 2013 16:37
2.0 aeg engine question...brass filings in oil vwmikey99 Ontario 4 June 14th, 2011 10:42
Page generated in 0.13805 seconds with 12 queries
[Output: 83.59 Kb. compressed to 72.00 Kb. by saving 11.59 Kb. (13.86%)]
