Go Back   TDIClub Forums > VW TDI Discussion Areas > Road Trips
Road Trips Discussions about road trips you have made with your TDI.
Old August 10th, 2017, 10:54   #1
jason_alh
Default 2003 Jetta TDI Road trip (Saskatoon Sask. to North California)
Just wanted to share a recent 2 week long road/mountain bike trip experience with my MK4 ALH Jetta (sorry no pictures loaded as of yet). We made several overnight camping stops along the way down to San-Francisco. Starting in Saskatoon SK. the first stop was Fernie B.C, then Rossland B.C, then Oregon and finally made our way down to San-Francisco. On the return trip we cut straight across back to Saskatchewan. Overall did roughly about 3700 miles of driving without any major issues. Only reported issue was going into limp mode during some long mountain grades. The car was heavily weighed down with gear, backseat and trunk packed to the ceiling. As well as (2) mountain bikes on the hitch rack. Only modifications are a Malone stage 1 tune and skid plate. We averaged about 50 to 60 MPG (Canadian Gal.), which I cannot complain about. I plan to clean the intake manifold which will hopefully alleviate any further limp mode issues.
jason_alh is offline   Reply With Quote
Old August 10th, 2017, 14:00   #2
h4vok
h4vok's Avatar
Not sure if you got a code for the limp mode you could check even if the engine light is not on there may be one. I am not sure what all the malone stg1 tune changes. If the boost limiter by atmospheric pressure was not set properly and left stock you were probably over boosting in the thin air. Looking at my malone eco tune in a map editor confirms that this is the case for my tune. 2150mbar limit at 700 mbar ambient is not good. Could be sticky vanes or actuator too.
EDIT: It is possible that another method of boost control for altitude is in the tune other then the boost limiter. I am not a professional just relaying my observations.
DLC520, Mufflerectomy, Self tuned MPPSv16, more linked below
My car thread
h4vok is offline   Reply With Quote
Old August 10th, 2017, 14:34   #3
Owain@malonetuning
All of our tunes of course account for altitude, it'd be very unprofessional if they didn't. Normally don't throw codes for limp mode, it'd be best to do some boost logging.
(are we supposed to use imperial gallons in Canada..?)
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is online now   Reply With Quote
Old August 10th, 2017, 15:47   #4
jason_alh
I plan to do some boost logging once I get a VCDS. I am pretty sure that the turbo/actuator is sticky, since I don't think that the PO drove this car properly. The car is running 100% better than when I bought it mostly from just "exercising" the throttle on the highway. Limp mode did not produce a engine code during the trip. I use imperial gallons which renders a higher number, its all preference.
First road trip in 2013 Jetta TDI JettaNocona VW MKVI-A6 Jetta Sedan (~ 2011+) 9 September 24th, 2013 22:45
2003 Jetta road trip - what maintenance? philh VW MKIV-A4 TDIs (VE and PD) 11 May 1st, 2013 07:45
North south road trip question RudyH VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 February 11th, 2011 16:41
Road Trip 2003 Blackknight Road Trips 2 December 9th, 2003 20:49
road trip to CALIFORNIA FROM Vancouver coolsio1234 Fuels & Lubricants 4 July 7th, 2002 18:29
Page generated in 0.15488 seconds with 12 queries
[Output: 64.42 Kb. compressed to 57.68 Kb. by saving 6.74 Kb. (10.46%)]
