Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old March 20th, 2017, 20:17   #1
brumbar
brumbar's Avatar
Default What do you think about OBD 11?
I just need to read and clear codes.
https://obdeleven.com
Got a CEL for misfiring old spark plugs, that I didn't change for 120 000 miles, yes I know change interval is 40 000, but was to busy with other things and the car was running good. Now after replacing the plugs, no more misfire, but the CEL won't go off, even after disconecting the battery for 2 hours. So maybe I need some scan tool.
brumbar is offline   Reply With Quote
Old March 20th, 2017, 23:21   #2
MagnumVW
Fuel Economy: 32ish mixed driving, 39-40 on long trips.
If you buy this $12 bluetooth scanner, you can clear codes using the Torque app on Android or something similar on iOS. I'm not sure if the free version of Torque can clear codes, but the $5 you pay for the full version is worth buying anyway if you do end up needing it to clear the codes.
Bluetooth OBD2 tool
MagnumVW is offline   Reply With Quote
Old March 21st, 2017, 10:04   #3
hey_allen
I like the ELM327 based bluetooth OBD2 adapters as well.
When I'm not data logging or otherwise needing to use the VCDS, the cheap bluetooth adapter is my go-to for diagnosing and monitoring the vehicles that I work with.
As Magnum mentioned, Torque is cheap, and surprisingly useful.
hey_allen is offline   Reply With Quote
Old March 21st, 2017, 10:13   #4
brumbar
brumbar's Avatar
Default Torque
Do they have Torque version for IOS ?
Old March 22nd, 2017, 00:23   #5
MagnumVW
It's not on iOS I don't think, but you can find one that does the same thing. Check out the list provided at this link. I'm sure you'll find something that suits your needs.
List of OBD2 apps
Old March 24th, 2017, 10:21   #6
brumbar
brumbar's Avatar
Default I've got the adapter....
Bluetooth OBD2 tool
I ordered the adapter from your link. They are two kinds: One for Android only, connects via Bluetooth and another one for iOS - connects via Wi-Fi.
Received the black adapter today. Downloaded the free app. OBD Car doctor - works great. Cleared the code, "Cylinder No 2 miss firing"
If I need more, I can get the DASH COMMAND for $10.
Thank you guys for your help!
Old March 24th, 2017, 10:25   #7
brumbar
brumbar's Avatar
Default Adapter
The only problem, adapter does not work on diesel engines. I wish they make something similar for diesel. I still have my 1998 Jetta 1.9 TDI.
Old March 24th, 2017, 11:57   #8
hey_allen
Try one of the different software packages, at least the test version.
Torque (yes, apparently android only) does play nicely with my ALH TDI, just the same as it talks to a friend's Mini Cooper JCW.
What I'm getting at, you might just have software that's playing games, not the adapter.
Old March 24th, 2017, 18:12   #9
brumbar
brumbar's Avatar
The manufacturer stated that is not working on diesels, but I can try.....
Old March 28th, 2017, 15:10   #10
Nevada_TDI
Most of the ELM 327 OBDII adapters are version 2.x. My 2001 did not talk to my Torque Pro and after much frustration I read where a v1.5 would likely work; it did and still does. You will have to do a bit of searching on flea bay but they are available...
I cannot believe how many choices of what to monitor there are available for less than $15.00 including shipping. Good luck.
I am using an Android phone.
_______________
2001 Jetta GL TDI, 35/15% Tint, Ventectomy, Catectomy, EGR-ectomy, Stage 4 TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Old April 6th, 2017, 14:52   #11
bassic83
TDI(s): 05 Golf TDI
Is there an OBD Bluetooth that will give me live data while driving? Tried a couple of ELM327 compatible ones, no luck. I have an Android phone, Torque Pro, just need to know if there is one that will work with a BEW. Things like water temp, throttle %, engine load, speed, RPMs, nothing fancy. I have a VAGCOM, and use it for codes, etc., but I like having more data than what I get on my cluster. 05 Golf TDI. Thanks
bassic83 is offline   Reply With Quote
Old April 8th, 2017, 15:11   #12
Nuje
I have three of them - bought from Amazon or eBay for less than $12 each.
I get live intake temp, coolant temp, engine RPM, among all the other things that Torque can scoop up.
Are you sure you're paired and set up correctly?
Nuje is offline   Reply With Quote
Old April 9th, 2017, 14:02   #13
Nevada_TDI
Not all ELM327's are created equal; exactly which ones do you have?
_______________
Old April 9th, 2017, 14:11   #14
Nuje
Link is dead now, but in 2014, I bought this (title):
"Yongtek ELM 327 Bluetooth Obdii Obd2 Diagnostic Scanner, Elm327 Wireless OBD 2 Scan Tool Check Engine Light CAR Code Reader"
-Amazon
$11.50
Old April 9th, 2017, 17:43   #15
Nevada_TDI
Nuje, thank you for responding but I was actually asking bassic83. I should have made that clear.
_______________
obd 11 Jonny5 OBD Scanners 6 November 24th, 2015 23:22
RockAuto Closeout Parts - 2000 TDI's (11-30-11) mag2 VW MKVI-A6 Jetta Sedan (~ 2011+) 1 November 30th, 2011 14:02
RockAuto Closeout Parts - 2000 TDI's (11-30-11) mag2 VW MKIV-A4 TDIs (VE and PD) 0 November 30th, 2011 13:43
1999.5 TDI 5 speed, respond by 11/1/11, Western Pennsylvania tyhoppy TDI Cars for Sale/Wanted 9 October 30th, 2011 11:46
Page generated in 0.18779 seconds with 12 queries
[Output: 120.72 Kb. compressed to 100.13 Kb. by saving 20.59 Kb. (17.06%)]
