burn_your_money
Intro
I'm giving some serious consideration to dropping a 5 speed ALH into a early Mazda5. I recently took my Beetle with my wife, 2 kids and a small 4x7 Uhaul open trailer loaded with a piano and a bunch of other stuff from Missouri to Ontario (13 hours) and the car did surprisingly well. I estimate I had 1300 lbs including the trailer behind me, plus 500 pounds including occupants in the car.
Base curb weight of my car is 2867lbs, which puts my total weight for that trip at 4667lbs. I was driving 72-75 most of the way home and averaged high 30s.
A Mazda5 weighs 3400lbs and should be more aerodynamic and have less rolling resistance than my Beetle towing a trailer so I have expectations of right around 40 mpgs. That would put a smile on my face.
One thing I'd need (eventually), is a bit more power. The car loaded was quite happy to go 60, a bit grumpy going 70 and felt near maxed out around 80. I like traveling at 77-78.
My car is 100% stock. If I go ahead with the swap, I'm leaning towards a Malone Stage 1 tune and 205 injectors. I might swap in a 11mm pump too.
The Money Spending Part
Clutch: What do I go with? I'm hoping to have my wife confident driving standard in the next month or so, so I'd like something that is easy to drive but that I'm not going to be replacing on a regular basis. Any suggestions?
Transmission: I haven't looked at ratios yet but I'd like something with a shorter 1st. All the other gears seemed fine while towing. I imagine the easiest thing to do will be to swap 1st gear. Any idea on a common transmission with a taller 1st? I'd probably bump second up a bit too just to narrow the gap.
Axles: I'm planning on getting a local shop to splice the Mazda and VW axles together at the correct length. Anyone ever done this before and have any insights? The other idea, is to find a wheel bearing that would fit in the Mazda knuckle and fit the VW hub in the center. I know VW offers some different length axles so I might be able to make something work. I haven't gotten under a Mazda5 yet, but I think the front track width is pretty close to my Beetle. Anyone have links to bearing sizing? I'd run steel rims and hub caps to hide the different bolt pattern.
Immobilizer: Can someone confirm that the 99 Beetle does not have an immobilizer? I don't see any dash lights that look like the immobilizer symbol on mine.
Clutch Master/Slave: If I use the Mazda master with the VW slave cylinder am I going to run into issues? What do I need to check and how do I do it?
What else am I missing?
