magna413
Hello, my problem was that the injector seals were bad. The upper red seal was even so bad it was visibly broken. New set of seals, injector bolts, rocker arm bolts and problem is history.
Well thought I would see if filling tank back up would help and sure enough it doesn't leak back and no bubbles at all in the clear line. Beginning to wonder if maybe the return line is no submerged in the tank properly and under half tank it allows the diesel to bleed back.
Will need to give it a week till the tank is back down to 1/2 again but will let you know.Try turning the key forward but not enough to start it. The pump should come on. Then turn off, then do it again. Three times, on the fourth try to start it. Let me know if it works, it works on gas cars/trucks. Sometimes you only need to do it twice. Just play with it.
But more often it was either the tiny fuel return lines on the injectors or the thermo tee on the fuel filter cracked or having bad O-rings. There are other said:So I started today with the filter, when I removed the Tee there was no suction noise and i could see the top of the filter so diesel is certainly draing back, etc so thought I'd follow you advice Dan and replaced the 2 O-rings. Started it up and and after a minute any bubbles were gone, have switched it off and will check tomorrow morning to see if The clear line drained back again. Will update tomorrow either way.
But thank you to those that post an also sorry to the thread originator for hijacking your thread and with the wrong type of TDi
I just discovered that there is a link between my failed tandem pump and my car producing white smoke. I have had a failed tandem pump for a few months now. I simply just let the car crank for a minute and it eventually starts. A couple of times now the car has started producing white smoke. I realized that changing the oil solves the problem. I drained my oil yesturday and had 5 quarts after I drained the drain pan into a 5 qt container. I figure there was probably another half a qt trapped in the motor. I only put 4 qt in the engine when I changed the oil. What is happening is that I believe fuel is mixing with the oil due to a failed tandem pump. Here is what it says in the VW manual.
"The tandem pump must be checked for internal leaks between fuel side and oil side after reinstalling a used tandem pump, for example after renewing or repairing a cylinder head and/or when installing a “short” engine. When leaking it is possible for the fuel to mix with the oil, which may cause the engine to fail. "
Carl, you are right on on this one!!!
Again I clamped the fuel hose overnight, and when I started it this morning at 25 degrees (even without my frostheater plugged in) it turned right over!
I had suspected that it was losing prime for a while, but had not gone this far to troubleshoot.
I will be adding a check valve this weekend!
I wonder how many people have been talked into a new fuel pump and labor (and talked out of $400) by the VW dealer just because their check valve failed?
A 10 dollar part and 5 minutes to fix...
Thanks again Carl!!!
First off your problem deserves it's own thread.....I would repost the above with a new thread title like "Help needed with issues after a run away".I am a newbie here but I'm desperately looking for some help.
I have a 2003 VW Beetle 1.9L TDI Diesel
219K miles with 1 prior owner. I bought this beetle in 2014 and all required maintaince was performed as I have documentation to verify this. About a month ago, I experienced a runaway. The runaway did not consume all of my engine oil. It was about 1/4-1/2 quart low. Initially bringing the car into the shop, they believed the runaway was due to being overfilled with oil. I assured them I highly doubted that scenario and asked if my turbo was to fault. They later told me the waste gate was stuck open but after working the gate, they were able to free it up. Now moving on......simultaneously after the runaway experience my engine is now experiencing long cranking and hard starts. The mechanic then ran various tests: a compression test (which I do not have the numbers for but according to the mechanic checked out good), an injection pump test--which they said was the culprit. Cylinder 2 was misfiring and the injection pump was thought to be the problem. Thinking this would fix the problem, I authorized the fix. Once the new injection pump was on the car started up great, according to the mechanic. Upon a road test, the car (according to the mechanic) started smoking so they checked the intercooler and oil had pooled up in here. My turbo had failed and fed oil into the intercooler, which the mechanic states caused the original runaway. So, at this point they advised a new turbo or to cut my loses and sell the car, which I was tempted to do but at this point since I had spent money to fix the injection pump I felt like my only option was to fix the turbo thinking this would resolve all my issues. They get the new turbo on and now the car began with long cranking and hard staring issues again. The smoking had decreased but still smoking some. They called and wanted to do additional testing at no cost to me aside from my time, which I thought was great and is. They did a cold compression test, checked the timing, fuel lines, camshaft, glowpugs amoung other I am not recalling. They have stated that they have run out of tests to do at this point and the last thing they would go to is cleaning my intake manifold and valves. Also, since the injection pump did not permantly fix my issue, they are not charging me for that service or several of the other things tested. This is a great shop and I am very pleased with how they are handling things but maybe someone here has had a similar problem and found a solution. Please help!!!!!!
Yup thanks. I fixed it earlier and tested it. Good as new. Im a happy camper. New fuel line cured the illness.If fuel is leaking out air is leaking in. And yep.
