Old September 16th, 2017, 10:56   #1
Default ALH head on AHU block?
Like the title says. Not sure if this has been answered somewhere else but doing some research for a future project. Want to use a good AHU block but use an ALH head so i can have a VNT, unleaking valve cover etc
00013cave is offline   Reply With Quote
Old September 16th, 2017, 11:10   #2
I've read it doesn't fit. A search will bring up the details.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
KLXD is online now   Reply With Quote
Old September 16th, 2017, 11:18   #3
Old September 17th, 2017, 22:20   #4
vanbcguy's Avatar
They're quite different, definitely won't fit.
There's nothing about the head that gives you the ability to use a VNT. All 8V heads have the same exhaust ports.
Sent from my LG-H873 using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old September 18th, 2017, 06:46   #5
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Ports and bolt spacing are different - just do an image search on ALH AHU head gasket, and you'll see that they don't match.
VNT on an AHU? many have converted. Generally requires fabrication work on the rear engine mount, and a tune of course.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
AHU block, ALH cylinder head? 6speed TDI Power Enhancements 15 February 9th, 2018 13:56
FS: AHU block and head validius Private TDI Items for Sale/Wanted 1 November 19th, 2012 14:17
Head/Block Differences from AHU to ALH? D_Bat TDI Power Enhancements 3 March 2nd, 2011 08:34
1996 Jetta AHU engine block and head for sale BOBB1946 Private TDI Items for Sale/Wanted 4 May 17th, 2010 04:22
AHU head on ALH block? wingsfan3415 VW MKIII-A3/B4 TDIs 4 February 28th, 2010 19:30
Page generated in 0.13138 seconds with 11 queries
[Output: 67.01 Kb. compressed to 59.10 Kb. by saving 7.92 Kb. (11.82%)]
