Old September 16th, 2017, 09:47   #1
damac
TDI(s): none
Question is there supposed to be a little movement in front mount?
i'm new to these parts, i thought i bought what i needed from a donor and new old stock vw hydro mounts with subframe as well like people say to do here to swap into my mk2 golf. so for the front mount it lines up with notch up top so it doesn't spin and is held on by a bolt. underneath sits rubber cup with metal shield on the bottom and is held on by another bolt. with these tight i don't think either the cup or swiss cheese piece fits in the frame very tight? with the other mounts bolts cracked i can shift the front around a bit up/down and side to side to where it looks like its sitting at an angle. i'm not sure if this is correct or if i tighten the other motor mounts it just gives the front a place to move around a bit every which way?
damac is offline   Reply With Quote
Old September 16th, 2017, 13:32   #2
ToddA1
Fuel Economy: Dismal
Is that a B4 subframe? I think that's what you're u need to use.
Btw, your pic is huge. Should scale it down.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is online now   Reply With Quote
Old September 16th, 2017, 18:45   #3
Steve Addy
TDI(s): 97 Mk3
It would have to be a B3 VR6 subframe or a any B4 front subframe to work with the native swiss cheese front mount. There's a hydro version of the front mount but it was only used on the VR cars and it was only a disc piece bolted underneath and covered by a metal cap.
The top bolt only holds the bracket to the mounting center, it doesn't hold the mount in place, that's basically done by the weight of the engine even though there's a bolt underneath.
I don't really see a problem with what you have unless there's a clearance issue between the oil filter and the front subframe. It looks to me like it fits fine.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old September 16th, 2017, 20:13   #4
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
Don't take that to mean you can skip that lower bolt and buffer underneath by any means. If that bolt breaks, the engine twists toward the firewall every time you accelerate too hard. Ask me how I know... Lol.
2003 Jetta TDI - 11mm IP, R520s and FMIC from the Red Death, HE221W (shooting for 26PSI), 1.8T pancake, DIY 3" OMI, still working on the DIY tune... its a learning process.
1996 Passat TDI - "Red Death" RETIRED. Had: Malone stg 1, 11mm IP, R520s, GT15/17 hybrid, FMIC, ETC
1997 Passat TDI wagon - Running donor or beater for sale, rough body
ketchupshirt88 is offline   Reply With Quote
Old September 16th, 2017, 21:30   #5
Steve Addy
TDI(s): 97 Mk3
Lol, absolutely, you can't skip that lower buffer by any means, that's just asking for a problem. I have heard of others who forgot to install the lower bolt as well.
Steve
Dogbone (Pendulum) Mount Movement - Is it bad? mwc360 VW MKV-A5 Golf/Jettas 2 April 27th, 2016 15:23
Videos Of Motor Mount Movement whiplash willy VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 November 13th, 2012 12:10
Excessive tranny mount movement? srmichi TDI 101 10 December 6th, 2011 18:25
99 Jetta TDI Strut Mount Movement Green Waters VW MKIII-A3/B4 TDIs 2 December 4th, 2007 15:04
Movement of Flywheel Plate? not supposed to be? Ebtyr VW MKIV-A4 TDIs (VE and PD) 1 May 12th, 2005 18:52
Page generated in 0.13242 seconds with 11 queries
[Output: 70.57 Kb. compressed to 62.62 Kb. by saving 7.96 Kb. (11.27%)]
