DSG Transmission Oil Temperature summary
Roqfud
Massachusetts, USA
2009 Jetta, 2015 Golf Sportwagen
OBD access to VW's DSG Transmission Oil Temperature seems to be a perennial question with mention in many threads in this and other fora, but I don't see it answered definitively anywhere. From what I can tell no one so far has discovered how this information is accessed by the system but we suspect it is accessed somehow because DSG overheating triggers a check engine condition.
I have seen proposals for a block and PID but none appear to have panned out. I may be wrong but I thought it might be helpful if my and others' research in this forum were summarized here. I'm a noobie at this area and my contribution won't likely be valuable beyond what I have written so far..
1854sailor
Resident Curmudgeon
Westerly, RI
2015 Golf SE SportWagen, 2015 Golf SE Hatch Back.
ScanGauge X-Gauge VW specific coding for Transmission Temperature: TXD - 686AF10105, RXF - 031A04410505, RXD - 2808, MTH - 00090005FFD8, Name - TFT, Units - Degrees Fahrenheit.
Roqfud
Massachusetts, USA
How does that ScanGuage info translate into OBDII block and PID values?
What header do we use?
