Old September 14th, 2017, 11:11   #1
VWWV
Fuel Economy: 48hw/36town
Smile Hurricane Irma
Unsure if this is right section. Please move if needed.
1. Hurricane irma eye passed over us with inevitable power loss on Sunday. Power was restored today (Thursday) Whoopee. During those long days and longer nights while my neighbors relied on generators...we used an inverter hooked to the battery of my 1996 B4, 1Z The inverter outpur is 400 Watts and with that we were able to power a couple of curly 60 watt bulbs, 2 pedestal fans( wattage unknown) and a 55 inch LED tv, along with the satellite receiver. The TDI idled in my driveway at the spec'd 900 rpms for 10-12 hours a day for 3 1/2 days without fail. The temp gauge never exceeded 190 degrees and the fans only came on one time. I did have to prop the hood open after the inverter overheated a couple of times. I disconnected the inverter and shut down the engine when I went to bed late at night. I haven't yet refilled the fuel tank but the gauge shows I might have used 2 gallons. THIS CAR IS 20+ years old. I think that's amazing!!! I plan to load up the tank with DieselKleen and get out on the highway for that time-honored Italian tune up in a day or so. This is not my first time doing this inverter thing. I once ran an inverter for 5 days from an 86 Jetta NA with the same results. I'm not sure what is the maximum watt inverter one can operate from the 90 amp Alternator but I intend to find out and
upgrade, if possible? VWVW
96 Passat TDi Candy White 100 K. mi, ventectomy, cat injector disabled.
WV - where relativity is more than just a theory.
TERM LIMITS NOW
VWWV is offline   Reply With Quote
Old September 14th, 2017, 11:16   #2
Jetter_Sprinta
Jetter_Sprinta's Avatar
Fuel Economy: Better than a Prius ;-)
The practicality of a B4 never ends!! I'm glad you all made it through the storm--and especially that the Passat didn't get flooded!
Home of "Krappy Wagon" + a few others!
Jetter_Sprinta is offline   Reply With Quote
Old September 14th, 2017, 11:23   #3
vanbcguy
vanbcguy's Avatar
Great thing to be able to do in an emergency!
I'm not sure that the alternator can reach its full output at idle - I suspect it needs a bit more RPM to do that. 90A at 14V is about 1200W, of course the car will be using some of that for itself. A 120A alternator is a direct swap, that can generate 1600W though again I don't know what RPM that would be at.
It should be mentioned that TDIs don't particularly like to idle a lot. The lack of cylinder pressure can lead to poor ring seal over time. But in a disaster scenario like you're going through I probably would have done the same thing.
Keep your eye out for an old VW 1.6 diesel if you ever want to build yourself a generator. You can easily run your whole house from one, plus it'll run on anything you can get your hands on (diesel, hydraulic oil, motor oil, veggie oil, etc).
Sent from my LG-H873 using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old September 14th, 2017, 12:22   #4
Stromaluski
Stromaluski's Avatar
That's an interesting idea. I would have never thought of that. I'll have to look into it since I could probably get a 1.6 for almost free, if I wanted.
-Andrew
Stromaluski is offline   Reply With Quote
Old September 14th, 2017, 13:31   #5
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Excellent - I did something similar after an ICE storm up here.
Had to run my Grandmother's boiler off my car for 8 hours to heat the house. Temperature was dropping to the point where the pipes were about to freeze.
Used my 1000w travel inverter and some really sketchy wiring to get 110v across the 50 feet from my neighbour's driveway and into the basement.
Worked like a charm, and used negligible fuel. Didn't have to worry about overheating either.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old September 14th, 2017, 13:40   #6
vanbcguy
vanbcguy's Avatar
If you get really clever you can rig up a heat exchanger to keep your water tank hot too... :-D Plenty of waste heat with an IDI.
Old September 14th, 2017, 15:12   #7
iluvmydiesels
TDI(s): AHU
Fuel Economy: mk2's about 48mpg, mk3 ~43mpg thats @(near)80mph(-/+).
amazing and good story. although i has one (serious) problem associated. i doubt its really that good to idle a car for more than 10mins, not to say 10hrs or more. it can be trying to rev it up (some) that much/from time to time.
small fleet of mk3 tdi
have exp on mk1&2, idi
other vw interests
iluvmydiesels is offline   Reply With Quote
Old September 14th, 2017, 18:51   #8
turbodieseldyke
turbodieseldyke's Avatar
TDI(s): 98 jetta
Fuel Economy: 50
Somebody should invent a hackaday/instructable bolt-on generator, so I won't have to.
- A dyno rig made of 6" PVC pipes. Jack up the front end, lower it onto the dyno, and don't forget to chock the rears.
- A genny that bolts directly to the front hub (4x100 or 5x100 pattern)
- A rube goldberg array of JY alternators bolted to 2x4's, all turned by one longass belt
- Maybe a custom-built alternator, with extra stators, rotors and regulators
These engines are capable of 90 HP, or 67 kW. Lots of wasted potential, if you only get a few hundred watts. In a real bad situation, you could be that "Monsters on Maple Street" guy from the Twilight Zone - deciding on a whim which neighbors get to live or die.
turbodieseldyke is offline   Reply With Quote
Old September 14th, 2017, 19:15   #9
ToddA1
Fuel Economy: Dismal
Any reason you'd run a gang of alternators and not an AC generator head?
OP, I'm guessing your alt was swapped? Should be 120A, but it's good to hear it kept you going. I have a friend in Boca and she came back to NJ, before the storm hit. Power has been out for over a week.
I've priced diesel generators a few years back and they're pricey. I'm curious what one could be built for, cost wise.
I ended up buying a 10kw/8kw gas/propane unit for $500 on a Black Friday deal. I installed a generator inlet box that feeds a primary on a breaker lockout, in my breaker panel.
Bought some 6/4 SOOW and the outlets on Amazon and eBay. Wired up a cheap annunciator that alerts me when utility is back on.
Total project cost me under $700.
Tested it a few weeks ago and it was able to run a bunch of lights (converted 95% of the house to LED), AC, kitchen, home theater, surveillance system, etc. more than enough to keep me comfortable.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old September 14th, 2017, 22:17   #10
Steve Addy
TDI(s): 97 Mk3
I've thought about the same things, what would be required if power went down for any length of time. In the mid-west we have the ever popular ice storms that can down power lines for quite a while.
I have a very tiny generator that I was gifted for doing some work for some very nice people. I've never run it and based on what it looks like I don't think it's ever been run. I need a carb float bowl o-ring but otherwise I've gone through and cleaned it and checked out most everything. If I had to guess I'd say it's from the late 70's perhaps, the brand I don't readily recall.
I need to see if it actually works but I would guess that I could power the furnace and refrigerator in the winter should the need arise. The fuel tank isn't what I would call large however.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Hurricane Harvey... SoaceMunky TDI 101 13 August 31st, 2017 18:22
Hurricane Sandy POWERSTROKE TDI 101 50 November 16th, 2012 11:33
Hurricane Katrina lostime Road Trips 2 August 18th, 2006 09:52
Hurricane Frances eluwak Eastern USA 21 September 12th, 2004 06:07
Hurricane Charley LWB053 Eastern USA 17 September 9th, 2004 05:35
Page generated in 0.14786 seconds with 11 queries
[Output: 101.69 Kb. compressed to 86.68 Kb. by saving 15.02 Kb. (14.77%)]
