Old September 11th, 2017, 20:18   #1
Rapidrob
Rapidrob's Avatar
Fuel Economy: 49 high way 48city 38 4x8 foot trailer
Default Vacuum pump suction readings.
I cannot find anywhere what the Vacuum pumps suction readings should be?
Some post show as much as 29" of mercury.
What is considered normal with no leaks?
Rapidrob is offline   Reply With Quote
Old September 11th, 2017, 21:37   #2
\/\/0J0
\/\/0J0's Avatar
Fuel Economy: At least 2x that of my TJ
29 inHg would be ideal but a reading over 20 inHg is certainly acceptable
Sent from my mobile look-at device
I miss my TDi
"Those willing to sacrifice Liberty for Security deserve neither" -Ben Franklin
\/\/0J0 is offline   Reply With Quote
Old September 11th, 2017, 23:32   #3
vanbcguy
vanbcguy's Avatar
I get about 22-24" on mine.
Sent from my LG-H873 using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old September 25th, 2017, 18:05   #4
Mongler98
in order to get a real reading on the vaccum you need a micrometer, the cheep ones are junk and you will pay about $500 at the very least for a GOOD one that will actually work. Rule of thumb is, vacuum it down for 1 hour and turn off all the valves and let it sit overnight or for a full day. if the needle moves AT ALL, you have a leak. To truly get down to a level you should be at for a perfect job, you need to flush all your lines out and change the oil in the compressor and new dryer because of contaminates. In a nut shell, just vac it down for 1-2 hours and let it sit for 1 full day. if nothing changes than your golden. if the system always had a good charge on it than just weigh in new refrigerant, dont do this any other way. If its in need of service, change all your o rings, the valve, dryer, and flush all the lines and evaporator with AC flush followed with nitrogen purge. Pull a vacuum for 1 hour and let it rest, if good, fill with nitrogen and do a bubble test with soap water than vacuum it again. Now weigh it back in and enjoy. there is more to meet the eye about this stuff and if you want you can PM me and i will help you out. My father is an Master HVAC and know too much about this for my own good.
Old September 25th, 2017, 20:17   #5
KLXD
What's all that got to do with the vacuum pump on the engine?
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old September 26th, 2017, 09:28   #6
Ol'Rattler
Ol'Rattler's Avatar
Nothing. What type of $500 micrometer do you need for air conditioning service?
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old September 26th, 2017, 15:46   #7
\/\/0J0
\/\/0J0's Avatar
Yeah, I'm trying to figure that one out too. I mean you could buy a nice starret for about 125, but I fail to see how it will measure vacuum, or be affected by it for that matter.
I miss my TDi
Old September 26th, 2017, 16:58   #8
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
I have a Lufkin 1" and 2" micrometer. Beautiful, had them for decades. Can't pull vacuum with either one.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is online now   Reply With Quote
Old September 26th, 2017, 19:27   #9
ToddA1
Fuel Economy: Dismal
Micron gauge.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old September 27th, 2017, 07:07   #10
Rapidrob
Rapidrob's Avatar
I bought a used one from a member here and am still waiting for it to show up.
To test the pump I was going to use a drill motor or chuck it in my lathe to do a quick test of the vacuum.
Does the pump spin CW or CCW?
Old September 27th, 2017, 07:48   #11
KLXD
CW As viewed from the shaft end.
I wouldn't test it that way. It normally gets a constant oil supply from the engine. A brief spin with a drill probably wouldn't damage it if it has residual oil in it but I doubt you'd get a true reading of its output.
Edit:
Oops. I was thinking of the ALH pump. The AHU is gear driven by the accessory shaft. You could probably tell by looking at the wear on the pump gear which direction it turns.
I think the accessory shaft turns CCW since it's driven by the back of the belt. That and the angle of the gear teeth would tell you.
Again, the vanes rely on a nice layer of oil to effect a seal with their bore...
Old September 27th, 2017, 09:25   #12
Ol'Rattler
Ol'Rattler's Avatar
The best way to test it would be to connect a vacuum gauge directly to it and just run the engine.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old September 27th, 2017, 13:29   #13
Vince Waldon
Vince Waldon's Avatar
If you remember that it spins at half engine speed and make sure there's some clean oil on the pump shaft I think a quick spin at 500-1000 RPM is probably not too risky.
You will know in seconds if it works or not... as long as you get 20+ inches of vacuum you're good to go.
The vacuum supply is used to power the brake booster and also the turbo actuator and EGR valves... fed-back systems for the most part, so the actual value is not super critical.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old September 27th, 2017, 13:55   #14
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
If you are evaluating the performance of the vac pump, test it by itself, as well as hooked up to the booster - a perceived faulty pump may just be a vacuum leak somewhere.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old September 27th, 2017, 16:15   #15
Vince Waldon
Good point.
Always tricky to lend constructive help without knowing the context... aka... the actual issue at hand.
Fuel injection pump suction Boriquakid TDI 101 1 August 31st, 2013 20:07
Vacuum readings dogder VW MKIV-A4 TDIs (VE and PD) 0 October 10th, 2011 07:32
vacuum readings for TDI LNELSON TDI 101 0 January 14th, 2006 11:01
Help, please, with drill pump suction oil change neimis VW MKIV-A4 TDIs (VE and PD) 18 January 14th, 2003 06:00
Gravity oil change versus suction pump Jersey Devil Fuels & Lubricants 6 July 16th, 2002 10:09
Page generated in 0.15303 seconds with 11 queries
[Output: 128.91 Kb. compressed to 107.15 Kb. by saving 21.76 Kb. (16.88%)]
