Old September 9th, 2017, 09:10   #1
mustangmarty
Fuel Economy: 33 mpg on the interstate at 65mph with windows up and no a/c going
Default Exhaust Manifold to Turbo Gasket...
https://www.partsplaceinc.com/vw-ahu...set-21947.html
Would y'all recommend using this gasket between the turbo and exhaust manifold or no? I have an exhaust leak from behind the middle of the engine. I don't think it's coming from that spot. And I don't want to warp the flange there by sandwiching a metal ringed gasket someplace is not supposed to be.
mustangmarty is online now   Reply With Quote
Old September 9th, 2017, 09:24   #2
iluvmydiesels
TDI(s): AHU
Fuel Economy: mk2's about 48mpg, mk3 ~43mpg thats @(near)80mph(-/+).
i dont use one, and its ok. didnt look at link, if i remember its an expensive gasket.
small fleet of mk3 tdi
have exp on mk1&2, idi
other vw interests
iluvmydiesels is offline   Reply With Quote
Old September 9th, 2017, 18:24   #3
ToddA1
Fuel Economy: Dismal
The triangular gasket is not used from the factory. It's a metal to metal seal.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old September 9th, 2017, 22:50   #4
Steve Addy
TDI(s): 97 Mk3
There wasn't one when I dismantled my engine for project and I didn't put anything in there when I reassembled it.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Exhaust manifold gasket bigcam01 VW MKIV-A4 TDIs (VE and PD) 3 February 6th, 2017 12:26
ALH Exhaust Manifold (Turbo) Gasket? heyman421 VW MKIV-A4 TDIs (VE and PD) 1 February 28th, 2009 14:08
A3 Exhaust manifold / Turbo inlet gasket TonyJetta TDI 101 3 December 27th, 2007 10:29
Exhaust Manifold Gasket carnotgas VW MKIV-A4 TDIs (VE and PD) 1 October 15th, 2006 14:02
Gasket between Turbo and Exhaust Manifold...???? Matthewhovis VW MKIII-A3/B4 TDIs 4 August 8th, 2005 14:24
Page generated in 0.12999 seconds with 11 queries
[Output: 61.95 Kb. compressed to 55.20 Kb. by saving 6.75 Kb. (10.89%)]
