Old September 6th, 2017, 06:20   #16
ToddA1
Fuel Economy: Dismal
What are you rebutting? HHO is not a cleaner burning fuel or more sulfur in fuel is not cleaner burning?
As for the black smoke, I see that as over fueling. I don't know how rigs run, but if their fuel mapping is not optimized, you'll get that belch. You don't see the black smoke when they're cruising, usually just under initial load.
My wagon will do the same when I jump on it.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old September 6th, 2017, 06:31   #17
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Higher sulfur fuel is dirtier burning fuel regardless of where and how it's burned. There's a reason it's been mandated out. Ultra low sulfur gasoline is just around the corner.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old September 6th, 2017, 08:01   #18
iluvmydiesels
TDI(s): AHU
Fuel Economy: mk2's about 48mpg, mk3 ~43mpg thats @(near)80mph(-/+).
Originally Posted by kjclow View Post
It is not a cleaner burning fuel. Just think of the thick black smoke you used to see out of any and all diesel trucks. There may still be some out there that belch, but it's a lot better now.
thats what you say seeing from the eye. what does that have to do with anything. wasnt almost all that smoke, whether extra or not, just about 'inert'. so what does an eye have to do with the bottom line. and now a days how many emissions and controls are on these diesels, how is any of it 'really' better. its just the illusion society has put there, you see you believe. its easier than knowing more. and right in front of you, and your senses,(supposedly). also take for instance gas vehicles, you almost all times see no smoke, does that mean anything? look at all the emissions and then thru the years how many controls have been added.
small fleet of mk3 tdi
have exp on mk1&2, idi
other vw interests
iluvmydiesels is offline   Reply With Quote
Old September 6th, 2017, 08:41   #19
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
ULSD even made my 1991 normally aspirated indirect injected diesel Jetta run cleaner. No, not scientific, but less visible smoke and less smell. And that was from the LSD stuff, which came around here in the late '80s. Before that, it was really awful stuff. THAT is where all the nasty black diesel images came from.
oilhammer
www.cardocautomotive.com
Old September 6th, 2017, 09:28   #20
vanbcguy
vanbcguy's Avatar
Home heating oil may not have the lubricity package they add to ULSD either... Many additive packages are mixed in the tanker truck (ie the dye itself for instance). If the batch is only going to be used as heating oil there's no reason to worry about lubricity.
Back to the on road / off road thing, most truck stops sell untaxed marked fuel for refrigeration trucks to use in their coolers, and for trucks with APUs, etc. It would be completely legal to purchase that for use in a sailboat and will be cheaper still.
Sent from my LG-H873 using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old September 6th, 2017, 15:06   #21
ToddA1
I can agree with this, although I don't know what it has to do with the thread. The thread did go off track, though....
I doubt the OP's sailboat is emissions checked.
-Todd
'97 B4: Stock
Rabbit build
Old September 7th, 2017, 04:51   #22
oilhammer
oilhammer's Avatar
All new engines sold here, from chainsaws to marine engines, have an emissions compliance label. They may not get "checked" after the fact, but they do need to meet certain requirements before sale.
And the quality of fuel is a key part of these engines being able to meet these requirements.
Lead as an octane enhancer went away from gasoline because it ruined catalysts. Sulfur has gone away (well, down to a VERY low level) from diesel because it ruined DPFs. Sulfur will be dropping in gasoline because those engines will be getting particle filters soon as well.
Keep in mind, this does not necessarily mean engines that do not have such devices cannot run on the newer fuels. But, in some cases (like alcohol content in newer gasolines) can have a detrimental effect on certain fuel system components that were not necessarily designed to deal with it. In some cases it becomes a constant problem, in other cases it is a one-time remedy and it is not likely to become a problem ever again.
oilhammer
Old September 14th, 2017, 11:04   #23
tbones
-Todd
Hi gang,
No, my sailboat is not omissions checked…
Thanks for the continued thread… I am enjoying reading people's comments here!
regards Steve
tbones is offline   Reply With Quote
Diesel questions TdiRN TDI 101 12 April 7th, 2016 09:16
Odd coloured diesel fuel. 2.2TDI Ontario 15 November 29th, 2013 05:31
NEW TO DIESEL. have questions about antigen/winter diesel beyco146 Fuels & Lubricants 5 August 12th, 2013 22:41
A TDI, an MB diesel, and an odd sighting... jimnms Sightings 6 May 16th, 2007 05:08
New To VW Diesel and have some odd ideas. (long) fretrunner9k TDI Power Enhancements 24 October 12th, 2006 17:25
Page generated in 0.15957 seconds with 11 queries
[Output: 90.34 Kb. compressed to 78.19 Kb. by saving 12.15 Kb. (13.45%)]
