Old August 24th, 2017, 20:24   #1
tbones
Default Check engine light and resonance issues
Hi gang,
I just posted about my trip from MD to Maine and back, And will post a few questions I have here:
My check engine light is randomly coming on both faintly and then full brightness and then going off.
I put my old Vagcom to check for codes, and the laptop's not working well enough to tell. The car ran flawlessly, and I'm just wondering if there might be an electrical problem with that check engine light circuit.
The other issuewas a rather annoying residence at about 2000 RPM. I've read where this could be due to a buildup of soot in the downpipe, I have not had a chance to bang on it to test and see if loosening any buildup in there makes it go away.if anyone has other ideas what could cause that, I will check into that, also.
As I stated in my write up about the trip, the car performed flawlessly, and was quite enjoyable to drive, aside from these two minor issues.
If anybody has any thoughts or suggestions on either of these, I'm all ears!
Regards,
Steve
tbones is offline   Reply With Quote
Old September 13th, 2017, 11:44   #2
dlee275
TDI(s): 96 B4V
My check engine light also has some variation in the intensity of its brightness. It stays on for a known issue I have, but sometimes it's dim, others it's fully bright, and occasionally it will go from one spectrum to the other while running. I have no other apparent issues with the cluster.
dlee275 is offline   Reply With Quote
Newbie TDI Owner - Issues with DPF/Check Engine Light brookygstone TDI (Diesel) Emissions 20 April 15th, 2015 06:00
TDI Newbie- 02 VW Bettle, puzzled with check engine light issues akmom0611 TDI 101 1 December 2nd, 2013 02:41
Check engine light after cold start issues TooDooIoo VW B5 Passat TDIs 5 August 17th, 2010 11:36
Check engine light issues - 2000 New Beetle WinterPhoenix TDI 101 7 October 7th, 2009 18:56
Any issues with refined BioD and ESP/Check Engine Light TDISurfer Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 28 July 13th, 2006 12:33
Page generated in 0.13291 seconds with 11 queries
[Output: 52.53 Kb. compressed to 48.63 Kb. by saving 3.90 Kb. (7.42%)]
