stucbr
How do i get to the mech?
When you've virtually no brakes because the system needs bled how are you supposed to get to the mech you use to get it done?
I put a new caliper on the back right (uk drivers side) and the pedals very spongy I've bled many cars and bikes through the years without a problem but not this time. I read about pressure bleeding and probably needs the abs unit bled too but in order to do it I need to either drive to the mechanic I use or drive to a local shop for a pressure bleeder...catch 22..
