Lmarjorie
- Joined
- Jun 8, 2014
- Location
- Great Barrington, ma
- TDI
- 2nd TDI Passat Wagon 2005 bought last spring in the southPassat Wagon TDI 2005 retired
Hello,
I need some help and maybe a referral. This is my second 2005 TDI Passat Wagon. I just bought 5 days ago in NC. When I left NC the first thing is I noticed gargling behind the dash and no heat. I had the car inspected and no mention of heater not working. I "googled" and came to the conclusion that it was air in the coolant lines and I could have them drained and pumped out when I got home.
Unrelated or not I just got on the interstate and a horrible noise coming from under the car. I pulled over on the interstate and discovered the plastic cover that covers almost the entire front half of the car had come off. I maneuvered it to hold until I got off the interstate and at a auto store purchased the nut that had fallen off and also the 3 plastic bolts that held the cover on that had come off. I mention this but not sure if it was related. I did open hood, oil fine and coolant.
4 days after purchasing I noticed on the forth day a rough start a couple of times particularly in the morning and louder than usual. I had driven on the interstate in cool 35-40 degrees in rainy weather about 30 miles. I came to the toll booth and stopped at toll both and noticed very thick smoke coming out exhaust that engulfed entire area. No lights coming on nor temperature being high. I decided to drive not even 1/4 mile to get to a gas station around the corner. I pulled over turned off engine popped hood and noticed immediately all the coolant (pink) fluid was out of the reservoir. Could not see pink at all... it was all gone. Looked at oil and it looked fine(not milky looking). NOT a single light came on my dash. My previous TDI that I had for 5 years had a coolant reservoir leak and the STOP engine light came on when the coolant got below the MIN mark. This car emptied the entire coolant and not a single light came on. No liquid inside the car.
Had car towed to mechanic late at night. Next day mechanic looked at it at 6pm before going on vacation for a week and said the car was leaking compression into the cooling system. He said when hooking the car up for diagnostics nothing came up on the reading of the car???
He said I could have damaged the cylanders but would not know until he opened it up when he got back.
I have to get this car fixed ASAP. Questions:
Any Idea what is going on here?
Is it just the head gasket?
Know a trust worthy mechanic in Western Mass that can help?
WHy would warning lights not come on?
Could it be the EGR Valve?
Why would he not get a reading of any kind when hooked up to diagnostics?
I had the car inspected before I picked it up. Could the inspector do a lousy job and the owner disconnect the warning lists hoping to hide a possible engine coor replacement? (Grew up in Italy where Italians are master deceivers... it left me with a constant questioning!))
Mechanic says it is probably more than the head gasket and suspect cylinder problems. LOTS OF MONEY HE SAYS>
Any guidance would be appreciated
