Think it's about time I add a build thread here. I have a 1996 TDI that I drove since new. Parked it last year due to rust and now slowly going through a full restoration. plan is to have it restored when it gets to 25 years old, as that is the minimum age in Belgium to get an oldtimer car plate.
Readout of the sticker:
PRCode: 1AC = anti-lock brake system (ABS)
PRCode: 1BA = standard suspension/shock absorption
PRCode: 1G7 = space-saving spare wheel (radial tire)
PRCode: 1KD = disc brakes, rear
PRCode: 1LY = disc brakes, front
PRCode: 1MZ = steering wheel for airbag system
PRCode: 1N1 = power steering
PRCode: 2A2 = delivery equipment, ballast weight
PRCode: 3AD = outer right rear view mirror: convex, manually adjustable from inside
PRCode: 3BC = outer left rear view mirror: flat, manually adjustable from inside
PRCode: 3YG = door pockets, front
PRCode: 8GD = alternator 90A
PRCode: 8L3 = roof antenna
PRCode: 8RM = eight loudspeakers (passive)
PRCode: 8TC = rear fog light for driving on the right
PRCode: B0C = component parts set, complying with vehicle type for Belgium, various parts
PRCode: C0K = steel wheels 6J x 14 offset 38
PRCode: G0C = 5-speed manual transmission
PRCode: H1L = tires 185/65 R 14 T
PRCode: J1D = battery 380 A (72 Ah)
PRCode: M2K = 4-cyl. turbo diesel eng. 1.9 L/66 kW TDIand MVEG 2 base engine is T2F
PRCode: Q4N = standard front seats w/ integr. storage trays and angular adjustment, left
PRCode: T2F = components for base engine, unit 028.C
Edit: Oldtimer age got changed to 30 years. So I'll register it as a normal car for a few years :/
